Results 1 to 8 of 8
  1. #1
    New Member
    Join Date
    May 2013
    Posts
    11
    Ireland
    MF fe35, 4cyl
    Default 4 cylinder Massey.
    Hi to all.
    I own a Fe35, 4cylinder. Is it possible to add additional hydrolics to the existing set up.
    The tractor has just one hydrolic coupling for a trailor ram and if possible I would like to be able to work a two-way ram on the system.
    Regards walyo.
  2. #2
    Super Star Member J_J's Avatar
    Join Date
    Sep 2003
    Posts
    18,924
    JACKSONVILLE, FL
    Power-Trac 1445, KUBOTA B-9200HST
    Default Re: 4 cylinder Massey.
    If you have hyd now, you should be able to add more hyd to the system.
    Tell us what you have now, and if it is open center or closed center.
    Then tell us the components you need.
    Hydraulics:
    Capacity: 8 gal [30.3 L]
    Pressure: 2800 psi [193.1 bar]
    Pump flow: 3.5 gpm [13.2 lpm]
    J.J.
    When I works, I works hard. When I sits and thinks, I goes to sleep.
    Git er done.
  3. #3
    New Member
    Join Date
    May 2013
    Posts
    11
    Ireland
    MF fe35, 4cyl
    Thanks J.J.
    I have no idea what open/closed center means. Hope the pic`s help.
    Walyo4 cylinder Massey.-image1414-jpg4 cylinder Massey.-image1412-jpg4 cylinder Massey.-image1413-jpg
  4. #4
    Join Date
    Sep 2003
    Posts
    18,924
    JACKSONVILLE, FL
    I only see one QD at the back of the tractor.
    Where is the valve that supplies the fluid?
    Is there a separate hyd pump for the implement?
    Open center hyd is where the pump is pumping fluid through all valves to the tank when the levers are in neutral.
    Closed center hyd system, there is no flow through the valve until you activate the valve lever. There is standby pressure at the valve.
    Show picture of the valve.
    J.J.
    Git er done.
  5. #5
    New Member
    Join Date
    May 2013
    Posts
    11
    Ireland
    MF fe35, 4cyl
    J.J.
    Once again I am lost. All I can say is when I operate the lever in picture 2 it raises the lift arms.Like-wise when I attach the trailor hyd. hose and pull the lever the trailor rises. Drop the lever and the trailor goes down. I cannot locate any other valves or switches .
    Excuse my ignorance. As you can see I`m not mechanically minded.
    Thank you for any help.
    walyo
  6. #6
    Join Date
    Sep 2003
    Posts
    18,924
    JACKSONVILLE, FL
    Does your pump have hoses or lines external on the tractor?
    If you have steel or hyd hose from the pump going into the tractor, then you can interrupt/cut into the hyd lines and insert a hyd valve and do what you want.
    If you can cut the line, then you would run a hose to the IN port of a loader or a remote valve and control a DA cyl, or multiple cyl of you get a three spool valve. .
    You will have to know a little bit more , and that is the new valve should have PB, and a PB adapter is required to feed the hyd fluid downstream to the 3pt input.
    The OUT port of the new valve should go to reservoir/tank.
    Show picture of the pump and hoses/lines from the pump.
    J.J.
    Git er done.
  7. #7
    Join Date
    Dec 2006
    Posts
    733
    Columbus, Georgia
    Kuborta B2400, L2900, L4330; Caterpillar D3B, John Deere 455D
    Walyo:
    You can adapt that system to operate a two way cylinder. It requires a selector valve and a directional control valve. The MF 35 series of tractors were built in great numbers and many are still in use. The demand for kits such as you need is great enough that several manufacturers produce them.
    You can easily find them on the internet.
    If I did it correctly, there will be attached a picture of one such kit. The most important part is the selector valve that replaces the plate on top of the transmission held on with two bolts, just below your right knee as you sit on the tractor.
    Attached Thumbnails Attached Thumbnails 4 cylinder Massey.-a16032-jpg
  8. #8
    New Member
    Join Date
    May 2013
    Posts
    11
    Ireland
    MF fe35, 4cyl
    Farmerford, many thanks.
    That is just the kind of information I need.
Similar Threads
  1. Massey-Ferguson MF-54 Backhoe SWING CYLINDER
    By Janner in forum Parts/Repairs
    Last Post: 06-21-2014, 05:03 PM
  2. Looking for the part # for a Massey Ferguson 20F 3 Cylinder Gas Service Manual
    By BleedingOrange in forum Massey Ferguson Owning/Operating
    Last Post: 12-03-2012, 07:44 AM
  3. massey 275 one cylinder hot
    By robbieie in forum Massey Ferguson Owning/Operating
    Last Post: 04-14-2012, 09:18 PM
  4. 1525 massey loader cylinder
    By hernando in forum Hydraulics
    Last Post: 08-22-2008, 02:44 PM
  5. Massey Ferguson FEL Cylinder Seal Replacement
    By pknchap123 in forum Parts/Repairs
    Last Post: 08-12-2005, 03:13 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2018 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
