Results 1 to 9 of 9
  1. #1
    New Member
    Join Date
    May 2013
    Posts
    3
    Dripping Springs, TX
    Deere 970
    Default Help on disassembling a cylinder for JD model 90 loader
    I'm trying to disassemble the cylinder on my JD model 90 loader to replace the seals. So far, I cannot figure how to get it apart and wonder if I need a special tool. A picture is attached, and when I put a wrench on Ring A and turn, both Ring A and Ring B turn together and all it does is rotate those parts in the cylinder. Based on the threads shown in the picture, Ring B is screwed into Ring A (or vice versa). Without ruining the threads, how do you hold one ring still, while turning the other?
    Attached Thumbnails Attached Thumbnails Help on disassembling a cylinder for JD model 90 loader-loader-jpg
  2. #2
    Advertiser kennyd's Avatar
    Join Date
    Jul 2003
    Posts
    12,911
    Westminster, MD
    John Deere 3720 CAB, 455AWS
    Default Re: Help on disassembling a cylinder for JD model 90 loader
    Welcome to TBN!
    The .pdf from JDParts is to big to attach, but if you register at www.jdparts.com for free you can get it yourself, there is a quick tutorial linked in my signature that can help if needed. Just put 90 in the search box.
    Here is a screenshot of the parts breakdown ( I think its the correct cylinder anyway-I am nor familier with that machine), I hope this shows what you need.
    Help on disassembling a cylinder for JD model 90 loader-90-loader-jpg
    KennyD
    www.boltonhooks.com
    Bolt-On Grab HooksTM, Bolt-On Clevis MountsTM, Weld-On Grab Hooks, Specialty Chain and Rigging Accessories, Specialty Hydraulic Components, and MUCH more!
    Visit our YouTube Channel
  3. #3
    Elite Member
    Join Date
    Jul 2006
    Posts
    4,409
    Northwest, WA
    Is there paint covering spanner wrench holes in ring "B" (12 and 6 o-clock position) ?
    ::Sent from a standard desktop keyboard::
    My Photobucket
  4. #4
    Elite Member wdchyd's Avatar
    Join Date
    Apr 2010
    Posts
    2,883
    Hooksett, NH
    Kubota B2320
    If it's not too late, the best way to hold the inner gland is to power the cylinder with hydraulics on the extend position.......it will push on the gland out and keep it from turning.....allowing you to tap on the retainer with a punch to loosen it (or use proper spanner)
    I usually do this before taking the cyl off the machine.......and after you completely reassemble, with the cyl on the machine, pressurize it out the same to hold gland and tap the retainer tight (while under pressure)
    there are no threads on the gland holding it in the cyl barrel, just retaining lock rings under the gland (push gland in to expose them)
    2010 Kubota B2320 FEL & BH65
    If it ain't fixed don't broke it!
    http://www.tractorbynet.com/content/...-month-wdchyd/
  5. #5
    New Member
    Join Date
    May 2013
    Posts
    3
    Deere 970
    Thanks for the replies, but no luck so far. @wdchyd, reinstalling it and putting it under a load is still an option, but the cylinder is already off and I'm an hour away from the tractor until next week. @Willl, I thought that was going to be the answer as well, until I stripped the paint off - see the new photos - those were just paint drips. @kennyd - thanks for the parts diagram, which is spot on, but JD doesnt make it clear how that retaining nut is to be removed.
    Attached Thumbnails Attached Thumbnails Help on disassembling a cylinder for JD model 90 loader-loader2-jpg   Help on disassembling a cylinder for JD model 90 loader-loader3-jpg
  6. #6
    Super Member Coyote machine's Avatar
    Join Date
    May 2009
    Posts
    7,203
    Southern VT
    '10 Kioti DK 40se/hst KL-401 FEL, loaded tires, KB-2485 bhoe, Tuffline TB160 boxblade, Woods QA forks, MIE Hydraulic bhoe thumb & ripper tooth, Igland 4001 winch, & GR-20 Log Grapple. Woods BBX72" Mower. Diamondplate aluminum canopy.
    Maybe it is removed from internal detents, only accessable once you remove what's removable now from the housing. Other choice is to take it to a shop where they've done this type of cyl dis-assembly many times with the right tools. Couldn't cost too much to undo it, then you repack it with new seals and away you go.
    2010 DK-40se/HST, KL-401 FEL, (reversible cutting edge). Titan Tree Shear. 72" Ratchet Rake. Fit Rite: Top-N-Tilt hydraulics & diverter. HLA Series 2000 7' plow, Aquiline MPC rear chains. Samuri Sickle bar.
    2016 Mechron 2200PS. 2016 Cub Cadet Pro Z 160 AW Steering, Kawa 23.5HP. 2015 Husky 322T AWD Rider, Combi 103 deck. Dr. Brush mower, & 42" lawn deck, & Dr. 6.5HP Trimmer/mower.
    Bunch of STIHL chainsaws: 011x 2, MS192T, MS200T, MS180C, MS230, MS270 (Wood Boss), 038 Farmboss.
  7. #7
    Gold Member
    Join Date
    Jun 2010
    Posts
    251
    Oliver 1655
    - I use compressed air to move the piston. This will allow you place pressure on the retaining ring & loosen the locking ring.
    - Once the retaining ring/cup is removed, I will apply a short burst of compressed air to pop the piston/rod assembly out. If a short burst does not work, DO NOT keep pressurizing the cylinder. Instead:
    - Anchor the base to your work bench & use a simple 1,000# hand cranked cable winch fastened to the other end of the bench to pull it out. I also attach a piece of rope around the rod which is anchored to the base with around 6" of slack to keep the piston/rod from flying when it does come loose.
    - I will also use my digital camera & take a photo of the way the seals/retainers on the piston are configured if it is not a common setup. It is no uncommon for the rebuild kit to not be identical to the original packing due to changes in technology. Most kits will have a diagram to work from.
    Wish you the best,
    John.
    John
  8. #8
    Join Date
    Apr 2010
    Posts
    2,883
    Hooksett, NH
    Kubota B2320
    Quote Originally Posted by Oliver1655 View Post
    John
    Using compressed air to hold cyl out i OK......but DO NOT use air to pop out the piston assy......You're gonna get hurt or the person standing in the room
    after the retainer is unscrewed from tapping with a punch, you need to use an aluminum/brass rod to tap the gland head in about 3/4" to expose the round retainer ring tucked inside a groove in the cyl barrel.......then the gland head/piston assy can be pulled out (come-along or hammer)
  9. #9
    New Member
    Join Date
    May 2013
    Posts
    18
    franklin KY
    ford 2000
    lightly tap the outer ring with a dead blow hammer all the way around the circumferance of the head the resulting shockwaves will clean any rust / pain out of the threads use a brass drift in the notches in the ring to tap the ring the direction you want it to go lefty loosy righty tighty once you have the outer ring off of the gland you have to push the gland backwards into the barrel to remove the large circlip holding the gland in the barrel if you have the jd kit alredy it comes with an orange ring you can fit into the barrel to make removal of the piston /gland easer
Similar Threads
  1. Replies: 15
    Last Post: 03-18-2013, 11:04 PM
  2. Model 52 loader bucket cylinder rebuild
    By WinterDeere in forum John Deere Owning/Operating
    Last Post: 10-03-2012, 11:48 PM
  3. Disassembling the power steering cylinder assembly (1975 Industrial 20) / 135
    By MFIndustrial20 in forum Massey Ferguson Classic/Vintage
    Last Post: 03-03-2012, 05:24 PM
  4. DU-AL curling cylinder for a model 105 loader
    By Little Red 284 in forum Hydraulics
    Last Post: 11-08-2011, 06:11 PM
  5. Disassembling Ford 711/722 life cylinder
    By sstra in forum Hydraulics
    Last Post: 03-17-2011, 10:57 AM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2017 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
