Results 1 to 4 of 4
  1. #1
    Join Date
    Oct 2006
    Posts
    108
    Default John Deere 350 Dozer - hydraulic pump
    I have a John Deere 350 dozer and today I noticed it spraying hydraulic fluid every where. Got it back to the barn and took the grill shell off and saw that the hydraulic pump case is cracked. Fluid flying everywhere. Does anyone know where a guy could possibly buy a used one at a bulldozer junk yard or would I be further ahead to just go to the JD dealer and take it on the nose? I've been looking on the web and it sounds like it is a Cessna pump that JD used. I wonder if I could get the Cessna number if I could buy one somewhere besides a JD dealer and maybe save a buck or two. Thanks in advance for any and all advise and suggestions.. RRM
  2. #2
    Super Star Member J_J's Avatar
    Join Date
    Sep 2003
    Posts
    18,923
    JACKSONVILLE, FL
    Power-Trac 1445, KUBOTA B-9200HST
    Default Re: John Deere 350 Dozer - hydraulic pump
    Look on the flange of the pump for the pump number.
    If you know the pump size, bolt hole spacing and shaft size, you might be able to find a replacement pump.
    J.J.
    When I works, I works hard. When I sits and thinks, I goes to sleep.
    Git er done.
  3. #3
    Super Member Tx Jim's Avatar
    Join Date
    Jan 2007
    Posts
    7,090
    Coyote Flats,Tx
    JD 4255/Kubota M7040 HDC
    Here's a pump I found on Google.
    Attached Thumbnails Attached Thumbnails John Deere 350 Dozer - hydraulic pump-capture-jpg
  4. #4
    Join Date
    Oct 2006
    Posts
    108
    Gentlemen, thank you very much. RRM
Similar Threads
  1. Hydraulic pump leak - John Deere 445
    By Allan Robinson in forum Hydraulics
    Last Post: 04-07-2013, 06:52 PM
  2. john deere 750 hydraulic pump
    By nicracing in forum Parts/Repairs
    Last Post: 07-28-2012, 08:08 AM
  3. john deere 6400 hydraulic pump
    By vers800 in forum Parts/Repairs
    Last Post: 01-02-2012, 09:12 PM
  4. John Deere hydraulic pump
    By tedturnwald in forum Parts/Repairs
    Last Post: 09-06-2011, 05:45 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2017 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
