Results 1 to 10 of 10
  1. #1
    Veteran Member sparc's Avatar
    Join Date
    Oct 2011
    Posts
    1,086
    NJ
    JD 4410, NH TC-25, Bobcat M610, JD X534, Dig-It Model 158, JD Ztrak 737. 6X4 Gator
    Default joystick question
    Is there a reason why a joystick could not be mounted so that the stick hangs
    vertical from the valve body as opposed to being on top as is normally done?
    Why? Don't ask. It's just a dumb question that I have not seen asked or answered.
    I don't see why myself but not being into hydraulics I have no idea. I know everything
    would be reversed in direction but that has nothing to do with if the joystick would
    operate reliably inverted.
  2. #2
    Super Member Tx Jim's Avatar
    Join Date
    Jan 2007
    Posts
    6,796
    Coyote Flats,Tx
    JD 4255/Kubota M7040 HDC
    Default Re: joystick question
    I see no reason why one couldn't mount the JS handle pointing down. Hyd oil will work running up hill or down hill.
  3. #3
    Join Date
    Oct 2011
    Posts
    1,086
    NJ
    I didn't see a reason why either but figured I'd ask. I would like to add remotes to my Ford 2600 for a Top link and a second remote possibly for tilt or for hydraulics on an attachment. And I was thinking of using a joystick mounted inverted under the controls for the loader (Bush Hog 2400QT)
    joystick question-imag1198-medium-jpg
    joystick question-imag1200-medium-jpg
    joystick question-imag1203-jpg
    You can see the setup as it exists now in the photos above which were taken right after I bought it early this spring.
    For the loader to work the lever has to be held back by a spring visible in the last photo. If I remove the spring the lever will want to return to the 3 pt. So as it works now if I have a BB or other attachment on the 3 pt and want to lift it I have to hold the lever forward to direct pressure to the rear. I want to do away with this mess mand add two remotes circuits.
    So what do I need to be able to use the rear remotes without having to disconnect the loader and also eliminate the jury rig that powers the loader now?
    I'd like to have a BB with hydraulic top link on the tractor at the same time as I would use the loader.
    Trying to figure out how much of this I can get from FitRite and what else I will need to complete this.
    Attached Thumbnails Attached Thumbnails joystick question-imag1199-medium-jpg
  4. #4
    Super Star Member J_J's Avatar
    Join Date
    Sep 2003
    Posts
    18,923
    JACKSONVILLE, FL
    Power-Trac 1445, KUBOTA B-9200HST
    You can use a joystick valve in whatever position you want.
    However it is not ideal for remotes. Regen might cause some confusion.
    A 2 to 4 spool valve with float, and other features would be better.
    Does the FEL valve go with the loader? Iif so, connect the IN hose and the PB hose together, and cap the OUT hose.
    If the FEL valve stays with the tractor, just remove the work port hoses and plug the work ports.
    J.J.
    When I works, I works hard. When I sits and thinks, I goes to sleep.
    Git er done.
  5. #5
    Join Date
    Oct 2011
    Posts
    1,086
    NJ
    The FEL valves go with the loader when its disconnected from the tractor.
    Then I am left with the two ports you see beneath the seat in the first photo.
    There are only the two hoses at present.
  6. #6
    Join Date
    Oct 2011
    Posts
    1,086
    NJ
    I'd like to add as part of this a set of ports like this. I found this same setup, same brand and model for $99 locally.
    Pioneer 1/2 in. Connect Under Pressure Kit, Upgrade Your Tractor - Tractor Supply Online Store
    Also found this 2 spool valve set for $189.
    Chief 2 Spool Hydraulic 4 Way with 3-Position Valve - Tractor Supply Online Store
  7. #7
    Join Date
    Sep 2003
    Posts
    18,923
    JACKSONVILLE, FL
    You should match up the GPM flow with your tractor GPM, otherwise, if your tractor pump flow is about 10 GPM, then find a 10 GPM two spool valve with PB for your remote valve.
    Something like this.
    http://www.surpluscenter.com/item.as...name=hydraulic
    J.J.
    Git er done.
  8. #8
    Join Date
    Oct 2011
    Posts
    1,086
    NJ
    Not doubting you JJ, just trying to understand, but how would having a valve with a higher flow capacity hurt system operation. If I'm running for example a max of 10gpm because that is my pumps limit i will still get 10 gpm through the valves. Icould see the reverse being a problem of course.
    I don't know where I could find the flow rate for this old Ford 2600. I will search the owners manual and see if its in there.
  9. #9
    Join Date
    Sep 2003
    Posts
    18,923
    JACKSONVILLE, FL
    Your Ford 2600 hyd tank capacity is about
    6.15 gal [23.3 L]
    As far as using a larger valve, by the time you move the valve lever 1/3, you are flowing the full pump flow.
    The purpose of matching the valve to the flow is to have good finesse /feathering, otherwise fine control.
    J.J.
    Git er done.
  10. #10
    Join Date
    Oct 2011
    Posts
    1,086
    NJ
    OK, that makes sense, I hadn't thought about that aspect of it.
    Thanks for explaining that JJ.
Similar Threads
  1. Joystick Valve Question
    By 8934 in forum Hydraulics
    Last Post: 09-19-2009, 10:01 AM
  2. Question About FEL Joystick
    By Haneyrm in forum New Holland Owning/Operating
    Last Post: 04-14-2007, 08:58 PM
  3. Yet another FEL Joystick Question
    By Tom_Veatch in forum Customization
    Last Post: 08-18-2006, 05:57 PM
  4. Joystick for FEL 723 - question
    By penokee in forum Kubota Owning/Operating
    Last Post: 09-13-2004, 09:08 PM
  5. Joystick question
    By THEBUS in forum New Holland Owning/Operating
    Last Post: 03-05-2002, 12:11 AM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2017 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
