CajunRider
I'm posting outside the Kioti forum to catch a wider audience. I need to replace the bucket cylinder of a KL249, which was actually a Rhino 2409 made by Rhino for Kioti. I found a cylinder on the Surplus Center ad on TBN that appears to be the same as mine. However, the maximum pressure rating is only 2500 psi. Is that enough or should I look for one with a 3000 psi max rating?
