Results 1 to 7 of 7
  1. #1
    Silver Member akpilot's Avatar
    Join Date
    Dec 2007
    Posts
    116
    Wasilla, Alaska
    NH TC40DA
    Default What Hyd cylinder to use?
    I'm thinking about building one of these post pounders, my question is there is only one hyd line to the pounder cylinder, so does that mean it is a single acting hyd ram? If I already had a Double acting ram and I only used one side and looped the other side would it still work the same?
    Attached Thumbnails Attached Thumbnails What Hyd cylinder to use?-p180rearmountedpostdriver-jpg
  2. #2
    Super Star Member J_J's Avatar
    Join Date
    Sep 2003
    Posts
    18,923
    JACKSONVILLE, FL
    Power-Trac 1445, KUBOTA B-9200HST
    Default Re: What Hyd cylinder to use?
    If the cyl has a single port, it is a SA cyl. It will have a breather port somewhere.
    A DA cyl can be used as an SA cyl. Insert a breather plug in the other port.
    What do you mean by looped?
    J.J.
    When I works, I works hard. When I sits and thinks, I goes to sleep.
    Git er done.
  3. #3
    Join Date
    Dec 2007
    Posts
    116
    Wasilla, Alaska
    NH TC40DA
    Thanks for the info J-J, I'll look for a breather plug. "Looped" my be the wrong term, the valve I have is ment for a DA cyl, if I set this up as a SA cyl then if the valve is pulled in the wrong direction!..... I didn't want it to "dead head" if I looped that side back to the return then "dead heading" wouldn't be possible, does that sound reasonable?
  4. #4
    Advertiser kennyd's Avatar
    Join Date
    Jul 2003
    Posts
    12,922
    Westminster, MD
    John Deere 3720 CAB, 455AWS
    I don't see how a regular cylinder will work well, the fluid needs to escape the cylinder very rapidly to allow the weight to drop fast. The Shaver drivers have custom made cylinders and require special plumbing to the tank to allow for this.
    That is unless I am mis-understanding how this one works.
    KennyD
    www.boltonhooks.com
    Bolt-On Grab HooksTM, Bolt-On Clevis MountsTM, Weld-On Grab Hooks, Specialty Chain and Rigging Accessories, Specialty Hydraulic Components, and MUCH more!
    Visit our YouTube Channel
  5. #5
    Join Date
    Jul 2003
    Posts
    12,922
    Westminster, MD
    Quote Originally Posted by akpilot View Post
    The system would only be deadheaded for a few seconds, thats what the relief valve is for. You can however plumb the spare port (on your remote) to the tank if it really bothers you.
    KennyD
    www.boltonhooks.com
  6. #6
    Join Date
    Sep 2003
    Posts
    18,923
    JACKSONVILLE, FL
    Those post pounder cyl only have about a 1 in rod , but very long.
    Hydraulic Requirements 3 - 4 GPM at 1500 PSI
    3/4 in return hose directly to tank.
    If you were to use a Prince DA valve or similar valve, Prince says to use the B work port and plug the A port.
    One TBN guy, said he was using a DA cyl as an SA cyl, but hyd fluid was coming out the other port/vent and messing things up. What was happening was the piston seals were leaking and the fluid has to have somewhere to go. So someone told him to run a hose from the vent port to tank, which you can do, but he should replace the seals in the cyl.
    J.J.
    Git er done.
  7. #7
    Gold Member
    Join Date
    Jun 2010
    Posts
    251
    Oliver 1655
    Consider checking your operators manual on connecting a single acting cylinder. Some tractors like my Oliver require you to adjust a flow diverter to allow the cylinder ram to return. Other may require it to be attached to a specific port. (Rod vs base, "A" vs "B") Another consideration in the air moving in & out of the vent & over time with corrode/pit the cylinder wall. Periodicly adding a small amount of hydraulic fluid through the vent location may slow down the corrosion. This is the reason most farmers avoid single acting cylinders when possible.
Similar Threads
  1. mf 135 hyd
    By butchtn in forum Parts/Repairs
    Last Post: 05-12-2013, 09:37 AM
  2. JD 1070 Hyd Problems
    By barneyrb in forum John Deere Owning/Operating
    Last Post: 05-05-2013, 11:19 AM
  3. changed hyd fluid
    By sam5570 in forum New Holland Owning/Operating
    Last Post: 05-03-2013, 10:32 AM
  4. changing hyd fluid
    Last Post: 05-01-2013, 03:30 PM
  5. not a tractor but it is hyd
    By sam5570 in forum Hydraulics
    Last Post: 04-29-2013, 09:16 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2017 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
