I'm assuming the camera on my phone doesn't like really cold temps as those weird rainbow artifacts are back.
You can see the big funnel with that screen that took 5+ minutes to drain every time I filled it up. Took a while to fill the hydraulics & made me really appreciate getting SUDT2. I still hate & can't quite read the site glass on the side of the tractor for hydraulic level. I assume it's a bit low as I filled it up with 95% of what I drained out & haven't opened up the 2.5 gal of extra SUDT2 I picked up.
I put most of the fender back on after the photos. I'll probably end up bending the joystick handle at some point so it almost ends up touching the fender when it limits out to the right & moves farther away from my leg. It works for now though. I think a longer handle for the 3rd function is coming with my cylinders. That will need a fair bit of cutting and/or bending to get out from under the seat, but that was expected & just futureproofing (I don't have anything to use that valve yet).
I'm reasonably happy with the little T manifold for the tank lines. It sticks out a little, but not much more than stock. I zip tied the in/out/tank lines to some of the steel piping running under the floor boards. It should keep it supported & out of the way. For anybody copying my designs, use #8 JIC fittings for everything, my notes are wrong. I would also add about 2" to 5 of the work port lines & 3" to the 6th. The frame mount for the fender under the seatbelt is a pain in the ***, especially with it being at a 45 degree angle. If you go a little longer on the work hoses though, there is nothing close under the frame to get in the way. When I reordered the in/out/tank hoses with the right fittings I got them as 46" (straight-straight) 44", 40" (straight-90). Glad I did. They might have been an inch or 2 long, but there was plenty of room for the slack & it made install easier. If somebody without welding skill wanted to do this, you shouldn't have to many problems. You could just mount the valve straight to the fender rather than the frame (Kubota did that for the PTO lever).
Getting the metal plug covers turned out to be a pain in the ***. You have to pull the QD connectors to put the keeper strap on. The hydraulic wrenches (mentioned in Number9L's post) were invaluable on every other hose & fitting, but unfortunately to small for the ag connectors & bulkhead fittings. I made do with some crescent wrenches, but those tight big fittings are a pain.
FitRite has been great help so far, given the confusion on #6 vs #8 JIC connectors & my general ignorance of hydraulics.
