Page 1 of 2 12 LastLast
Results 1 to 10 of 16
  1. #1
    Member
    Join Date
    Oct 2013
    Posts
    49
    St. Augustine,florida
    Ford 1510
    Question 3pt. bogs & chatters on Ford 1510
    OK finally got hydro sorted out & installed new (used) pump.. (I was having problems with intermittent 3pt hitch not working.) I am using a 30 inch 3pt scoop on a Ford 1510. 3pt has lots of power, goes up & down etc. However when it hits as high as it can go it bogs the engine down a few hundred rpms. (it IS the right pump) it did it from the first time I raised it after installing the new pump. . I put it up and down a few times to see if it would work out didn't seem to so I moved the upper limit stop on the control lever to stop it just before the bogging starts.
    Used it quite a bit yesterday and several hrs again 2day. Noticed that when at the high limit I set there is a slight "chatter" vibration especially when loaded (the scoop) and just a little when empty so I move the lever down just a tad & it goes away..
    Problem being, I am not getting all the lift now and the scoop doesn't quite tip straight down & sticky dirt doesn't all come out.. Any ideas/thoughts?? I could move the links in a hole & gain some hight but I am wondering why the bogging etc & if there is an adjustment or something..
  2. #2
    Super Star Member J_J's Avatar
    Join Date
    Sep 2003
    Posts
    18,924
    JACKSONVILLE, FL
    Power-Trac 1445, KUBOTA B-9200HST
    Default Re: 3pt. bogs & chatters on Ford 1510
    You should have a relief valve in the 3pt circuit, and when you raise the lever and hold it there, the relief valve should go off at a set pressure and the pump is working real hard will put a heavy load on the engine and lower the rpm's until you move the lever back to neutral or the load is removed.
    J.J.
    When I works, I works hard. When I sits and thinks, I goes to sleep.
    Git er done.
  3. #3
    Member
    Join Date
    Oct 2013
    Posts
    49
    Ford 1510
    So you are saying the relief valve isn't relieving?? Is it damaging anything usibg it as I have it set?? There is a relief valve within a divirter manifold where a loader could be attached etc.
  4. #4
    Join Date
    Sep 2003
    Posts
    18,924
    JACKSONVILLE, FL
    There should be a relief valve in any hyd circuit.
    If it is not working, the pump pressure could damage some of the hyd components.
    You should find out the tractor specs for the relief valve and use a 3000 psi hyd gage to check and set it.
    I don't know where you have it set, do you know. The pressure is usually set at 50 to 100 psi below the pumps max psi rating.
    Whoever designed the tractor, figured out all the specs for the tractor to work at a specific capacity, and in dealing with hyd, you are generally talking about load from the 3pt or loader, etc. Otherwise how much work can be accomplished with what. you have.
    J.J.
    Git er done.
  5. #5
    Elite Member
    Join Date
    Sep 2007
    Posts
    3,430
    Doniphan, Mo.
    Kubota L4240, B7800 & BX2660
    Your feed back is out of adjustment. Check your manual and see if you can find it in there. If not repost and someone can walk you thru the adjustment.
  6. #6
    Member
    Join Date
    Oct 2013
    Posts
    49
    Ford 1510
    Thanks for the info.. nothing in the owner/operators manual no specs, just stuff like the lifting load etc. .. I didn't kno it could be set, what to set it at, should be factory set, but I am not the first owner either so who knows.. or how to do it anyway. I am not mechanicly inclined. (the new pump was just take off old one & bolt on new ) If necessary, I have an extra manifold/diverter block I can take to local Cat, or JD, or kubota place. I would think they can find the correct settings.. There is no Ford dealer within reasonable distance.
    I do have a friend that can follow the directions but we wont have a hydro gauge available.
  7. #7
    Join Date
    Sep 2003
    Posts
    18,924
    JACKSONVILLE, FL
    You can build yourself a hyd gage test set for about $30.
    This liquid filled gage and a short hose with a QD to match your tractor QD, or a gage and adapter into a female QD.
    Mount a male QD in a tee in the IN port of the loader valve or wherever you want to measure.
    3000 PSI 2.5" LF LM GAUGE
    TSC might also have the gages.
    Attached Thumbnails Attached Thumbnails 3pt. bogs & chatters on Ford 1510-3000-psi-hyd-test-gage   3pt. bogs & chatters on Ford 1510-3000-psi-hyd-test-gage
    J.J.
    Git er done.
  8. #8
    Member
    Join Date
    Oct 2013
    Posts
    49
    Ford 1510
    Thanks J.J. BTW I am in St. Auggy 15 min from Ringpower. They may have it too. Now I need to find the setting.. We have a TSC also..
  9. #9
    Member
    Join Date
    Oct 2013
    Posts
    49
    Ford 1510
    ok found the max pressure is 2,133 psi now how to adjust the relief valve to about 100 psi lower than that?? I will find a gauge tomorrow..
  10. #10
    Join Date
    Sep 2003
    Posts
    18,924
    JACKSONVILLE, FL
    If the relief valve is adjustable, connect the gage and max the cyl until the relief presure shows, and then adjust it as needed,
    If the relief is adjusted using shims, then you need the right shims to increase pressure. They come in different thickness for a certain amount of pressure.
    J.J.
    Git er done.
Similar Threads
  1. 3pt lift on Ford 1510 tractor
    By Motis in forum Parts/Repairs
    Last Post: 11-10-2013, 08:08 PM
  2. 3pt lift on Ford 1510 tractor
    Last Post: 11-10-2013, 08:04 PM
  3. Checking & Fill Oil on Ford 3400 3pt hitch
    By pnystrom in forum Parts/Repairs
    Last Post: 05-28-2012, 02:38 PM
  4. mid 80's ford yt-16 bogs out
    By big in japan in forum New Holland Owning/Operating
    Last Post: 09-05-2009, 08:41 PM
  5. Stihl: 038 poor oiling & bogs when cutting at high speed
    By Coyote machine in forum Parts/Repairs
    Last Post: 07-07-2009, 02:51 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2018 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
