Installing 3rd Function Hydraulics - Electric over Hydaulic
   / Installing 3rd Function Hydraulics - Electric over Hydaulic #12
Nice write up. For some reason I can't see the last half of your pictures but maybe it's my computer.
If you have the info handy, add the details on all the fittings, couplers, hoses, switch and valve that you bought. Such as part numbers, price, purchased location etc. Helps followers in their shopping.
Thanks for posting!!!
I didn't go into the fittings and such because each install is different and unique to the tractor. The valve and subplate I bought was here. But I'd be glad to answer any specific questions on my install.
My lesson learned was don't buy local. Discounthydraulichose.com beat the snot out of the local guys prices. I was paying almost $10 for a 90 degree 3/8's fitting. :confused2: sheesh! They can keep it. It must have had gold in it.
   / Installing 3rd Function Hydraulics - Electric over Hydaulic #14
Great write up and even greater install!!!
:thumbsup::thumbsup::thumbsup:
   / Installing 3rd Function Hydraulics - Electric over Hydaulic #15
Yeah, that's why I suggested a detailed shopping list and location of purchase. Understanding that each install is unique. But many parts such as your valve would be shared and might help someone make a choice. Helps followers in their decisions. Surplus Center is a sponsor of this website and also has great prices with excellent service. But if you don't feel comfortable discussing details that's fine too. :)
Great install and writeup!!!
   / Installing 3rd Function Hydraulics - Electric over Hydaulic #16
that was a great custom install have a great write up too
   / Installing 3rd Function Hydraulics - Electric over Hydaulic #17
Been considering adding a grapple also. Great write up and install. Impressed with your rocker switch solution. Your experience mirrors many of my issues. More info please. Great job.
Captgb65, a grapple is barely a tool. It falls more into the toy category. Yes, you can get a lot of work done with it but you wont notice that because of all the fun you are having with you own hydraulic grab arm. :cool2: I highly recommend it.
What additional info are you wanting? I'd be glad to share.
   / Installing 3rd Function Hydraulics - Electric over Hydaulic #19
Where did you get the switch? Very nice job...
The switch I made was out of two components. I bought a stick shifter knob from a local auto parts store. This is the one I bought:
I got it at Oreilly's but you can get it from any other parts store like Autozone. $10, great deal. The inside is all rubber so it was easy to carve out for the switch with an xacto knife and drill.
The switch I chose was from ebay. You can find it here.
Its a Double Pole Double Throw but you will just use one side.
I carved out the handle so that I had a tight fit. It was easy because its a rubber inside so you can jam it in there for a solid fit without having to use screws or adhesives. It turned out as well as I'd hoped. I was real pleased with it. It attaches to the lever via 3 set screws so its a universal fit. You only need 3 wires coming down from the switch, your hot wire and your A and B to each of the coils on the valve. Here is a schematic. Please excuse the crude drawing but you get the idea.
You need to jumper your grounds to the neutrals and then tie the neutrals together. You then only need a single wire to ground to the tractor. The positive of each corresponding solenoid will wire into the switch.
Here you can see the three wires coming out of the switch.
Here is the underside labeled so you can see whats going on.
2014 GENIE GTH-5519 TELESCOPIC FORKLIFT (A60429)
2014 GENIE...
2019 Ram 3500 HD (A56435)
2019 Ram 3500 HD...
2019 Harley Davidson FLHTP Electra Glide Motorcycle (A56859)
2019 Harley...
2021 CATERPILLAR D3 LGP CRAWLER DOZER (A60429)
2021 CATERPILLAR...
2012 Husqvarna LTH18538 38" Riding Mower (A59231)
2012 Husqvarna...
2012 Ford F-250 4x4 Pickup Truck (A60460)
2012 Ford F-250...
