Results 1 to 5 of 5
  1. #1
    New Member
    Join Date
    Dec 2013
    Posts
    2
    ישראל
    john deere
    Question Hydraulic piston
    Hello everybody,
    I am new at this forum and I have a question for the ones who can help:
    I need to plan a hydraulic piston that is normally open.
    I can not trust the operator to open the piston, so he will have only to close the piston by hand and it`s need to be open automaticly.
    It need to be open after 30 seconds and after 10 seconds of delay.
    Who can help me with a solution for that?
    Thanks, Gadi
  2. #2
    Super Member Xfaxman's Avatar
    Join Date
    Feb 2013
    Posts
    7,984
    Meridian, OK
    Bobcat V417 Toolcat 5610 G TORO+Loader
    Default Re: Hydraulic piston
    to TractorByNet!
    When you say "hydraulic piston", do you mean hydraulic valve?
    Hydraulic piston-101351_inside_questions_2-jpg Hydraulic piston-hydraulic-valves-large-jpg
    Hold "Ctrl" (Control) and click on a picture or a Link, to open it in a new Tab.
    My Avatar, the TORO+Loader:
    Kwik-Way FEL and TORO Groundsmaster Put Together
    V417 Compact Telehandler: ​(This replaced my tractor): The best machine to do what I need a machine to do
  3. #3
    New Member
    Join Date
    Dec 2013
    Posts
    2
    ישראל
    john deere
    Quote Originally Posted by Xfaxman View Post
    to TractorByNet!
    Hi,
    Thank you,
    I am talking about the piston not the valve, but maybe the solution will be on the valve.
    It`s a double side piston that connect the device to the frame when the piston is open, and diconnect when it`s closed.
    I need that the piston, after using it, will go back to it`s open mode.
    Hope you will understand me
    Gadi
    Attached Thumbnails Attached Thumbnails Hydraulic piston-jpg
  4. #4
    Elite Member
    Join Date
    Sep 2007
    Posts
    3,430
    Doniphan, Mo.
    Kubota L4240, B7800 & BX2660
    Look up steering cyl.
  5. #5
    Super Star Member
    Join Date
    Mar 2008
    Posts
    15,543
    Northern Fingerlakes region of NY, USA
    Kubota L3830GST, B7500HST, BX2660
    Sounds like you need a electronic circuit and solenoid controlled relays...
    Any chance you could post a picture of the machine this will be used on?
    Edit, what do you mean by "open after 30 seconds and after 10 seconds of delay" Do you mean that it needs to stay open for 30 seconds then close, or???
    Aaron Z
    A human being should be able to change a diaper, plan an invasion, butcher a hog, conn a ship, design a building, write a sonnet, balance accounts, build a wall, set a bone, comfort the dying, take orders, give orders, cooperate, act alone, solve equations, analyze a new problem, pitch manure, program a computer, cook a tasty meal, fight efficiently, die gallantly. Specialization is for insects.
    Robert Heinlein, Time Enough for Love
Similar Threads
  1. That leather hydraulic piston ring
    By seanpaintsflames in forum Ford Vintage Tractors
    Last Post: 08-05-2013, 10:07 AM
  2. Piston Hydraulic Pump Source?
    By S Putnik in forum Hydraulics
    Last Post: 04-23-2013, 02:20 PM
  3. hydraulic piston rings
    Last Post: 02-19-2013, 01:19 PM
  4. Hydraulic piston info
    By ScottAR in forum Hydraulics
    Last Post: 09-26-2007, 10:13 PM
  5. Hydraulic Piston Rings
    By Anonymous Poster in forum Kubota Owning/Operating
    Last Post: 05-15-2003, 06:00 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2018 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
