Laser grading hydraulic valve issue.
   / Laser grading hydraulic valve issue. #1
Complete Turf Care
South Louisiana
2022 Kubota Grand L6060 (no loader), 2017 Kubota Grand L6060, 2011 Kubota L5740 HSTC-3, 1997 Kubota M4700
I have a laser grading system on an 8' blade that I use to grade athletic fields. As long as I had it on the New Holland TC45 in the pics, it worked fine. But, I bought a Kubota L5740 and on the first grading job with the Kubota, the valve shown in the pics failed. And, that valve cost about $800.
I was told that the reason it failed was because I had hooked up my hoses backwards and applied pressure in the wrong direction. I replaced the valve and went on to the next job. It seemed to work fine, but after about 8 hours of working, I'm starting to notice some oil coming from the $800 valve again. I'm not sure it will fail again, but I know that I can't afford to replace that valve every 10 hours or so.
Does anyone have any suggestions on what may have caused it to fail, and what could I do to prevent another failure? I do know that I did hook the hoses wrong on the first valve, but only applied pressure for a few seconds. I don't think I hooked them wrong for the second valve at all.
Could it have anything to do with the different tractor?
And, someone told me that I needed to add an inline 'backflow preventer' to prevent reverse pressure being applied to the valve.
   / Laser grading hydraulic valve issue. #2
What is the pressure rating of the valve.
Where in the series flow path is the solenoid valve.
Is there a relief valve that would protect it.
Just about every valve will get back pressure at some time, but I am not sure what you mean about back flow if the valve is hooked up correctly.
Is it connected in a series path with a continuous flow to tank, or is it an on/off type valve.
   / Laser grading hydraulic valve issue. #3
Is the blade behaving , or jumping around ?sound's like a pressure spike of sorts .
Thanks for responding JJ. You seem to have the most hydraulic knowledge here. I'll need some help to answer your questions.
What is the pressure rating of the valve. I really don't know. How can I find out?
Where in the series flow path is the solenoid valve.What is the 'series flow path'?
Is there a relief valve that would protect it.I don't know this either. How can I find out?
Just about every valve will get back pressure at some time, but I am not sure what you mean about back flow if the valve is hooked up correctly. The hoses are plugged into one of my remote valves on the tractor. To get pressure, I pull the valve lever and hook a bunge strap to keep it pulled back.
I'm don't know what you mean by 'series path'.
The blade does not 'jump around'. I can adjust the 'dead zone' on the receiver and I can adjust the response time too. As I get closer to my finished grade, I will reduce both of these adjustments.
   / Laser grading hydraulic valve issue. #5
Pressure rating for the valve would be in the valve description.
If you have a FEL, it has a relief valve, and you might check it for correct settings. If not, then the remote valve has a relief.
You may only have blown out a few o-rings on the old valve and maybe rebuild it.
If you are supplying the laser grader with fluid and you happen to use the 3pt and it builds up pressure to make the relief go off, that pressure will be reflected on any valve up stream including the laser valve. You may/will cause back pressure and interfere with the laser finite controls.
Back pressure will work against the incoming pressure, and damage seals, etc.
You might consider a 3000 psi hyd gage in the system to monitor and trouble shoot the hyd system. Cost about $30
Sample test set.
Actually, the part that I had to replace is known as a 'proportional coil'. I found the invoice for the one I had to get to replace the original, and the Sauer Danfoss part number is 157B4032. I don't get much info when I google that number.
I'm thinking that I need to add a 'check valve' or 'backflow preventer' or whatever you want to call it to protect the coil.
Here is a better look at how it's set up on the blade. I found a model number on the valve body of VDN-13973, but I don't get anything on a google search of that number.
You can see the oily area below the 'coil' where this new one is starting to leak. I just want to prevent ruining this one too.
   / Laser grading hydraulic valve issue. #8
Is the valve an open center or closed center type? Are both tractors the same regarding the type? Just curious, don't have any answers.
   / Laser grading hydraulic valve issue. #9
Both are open center Tractordata.com shows the Kubota at 14.7 gpm and the New Holland at 9.8 gpm.
This appears to be your setup Danfoss PVG 32 Proportional Valve Components : Neilson Hydraulics, Official Distributors of Bosch Rexroth and Sauer Danfoss , a stackable valve. You decide what you want and more or less mix and match.
Heres your solenoid Search Results : Neilson Hydraulics, Official Distributors of Bosch Rexroth and Sauer Danfoss ..Mike
**EDIT**
I just noticed the solenoid is listed as 24V, is that right, your system 24V?
Yes, that does seem to be what I have. But that company is in the UK. My tractor is 12 V as far as I know. It has one 12V battery
PALLET OF SCAFFOLDING PARTS (A52706)
PALLET OF...
Freighliner Tender Truck (A55302)
Freighliner Tender...
2016 Ford Fusion SE AWD Sedan (A55758)
2016 Ford Fusion...
ASSET DESCRIPTIONS & CONDITION (A56138)
ASSET DESCRIPTIONS...
2000 CATERPILLAR 320C EXCAVATOR (A52707)
2000 CATERPILLAR...
2016 Ford Explorer AWD SUV (A55758)
2016 Ford Explorer...
