Results 1 to 7 of 7
12-15-2013, 12:17 PM #1
- Join Date
- Nov 2013
- Posts
- 21
- Location
- Cassville
- Tractor
- Ford 1710
1710 Ford Tractor!!
I have a 1710 Ford Tractor. I want to know, can I add a remote Hydraulics for the rear of this tractor? It has already a front end loader on it now..
Thanks
12-15-2013, 01:45 PM #2
- Join Date
- Sep 2003
- Posts
- 18,924
- Location
- JACKSONVILLE, FL
- Tractor
- Power-Trac 1445, KUBOTA B-9200HST
Re: 1710 Ford Tractor!!
If you have hyd on it now, is it easy enough to add to the hyd system.
Tractor Data says you have a total pump flow of 7.8 GPM.
Is this a new type loader valve, with a PB port, and if so, you can add a remote valve.J.J.
When I works, I works hard. When I sits and thinks, I goes to sleep.
Git er done.
12-15-2013, 02:36 PM #3
- Join Date
- Nov 2013
- Posts
- 21
- Location
- Cassville
- Tractor
- Ford 1710
Ok, I'm not sure about that. What is a PB port??
12-15-2013, 02:50 PM #4
- Join Date
- Sep 2003
- Posts
- 18,924
- Location
- JACKSONVILLE, FL
- Tractor
If you have a loader valve with PB, you will have seven hoses.
You may have the PB port and not using it.
Look on your valve and see if there is a stamped PB by one of the ports.
PB is used to pass fluid to the next valve.
Valves with out PB use the return port to pass fluid to a tank/reservoir.J.J.
Git er done.
12-15-2013, 03:30 PM #5
- Join Date
- Nov 2013
- Posts
- 21
- Location
- Cassville
- Tractor
- Ford 1710
Ok I will go look!! We just got done with a 13" snow.. so it will be a bit before I post back!!
12-15-2013, 03:46 PM #6
- Join Date
- Nov 2013
- Posts
- 21
- Location
- Cassville
- Tractor
- Ford 1710
It has 4 coming from the side and 2 from the bottom with a fill line from the trans. Looks like you could add one more if need be, but I'm not sure.
03-14-2014, 12:05 AM #7
- Join Date
- Mar 2014
- Posts
- 2
- Location
- martin,Ga
- Tractor
- ford
I have a 1710 ford tractor with 3 lines coming from the transmission to the control valve for the front loader.Can I hook into 2 of these lines for a 3 point hitch backhoe?If so which lines do I hook into?
Similar Threads
Ford 1710 tractor starting problem part 2
By Francis Kingz in forum New Holland Owning/OperatingReplies: 19Last Post: 06-26-2016, 10:53 AM -
Need Parts for 1710 Ford Tractor
By tom17 in forum Parts/RepairsReplies: 0Last Post: 10-19-2013, 03:42 PM -
Anyone know of a Ford 1710 Parts tractor around???
By Robert_in_NY in forum New Holland Owning/OperatingReplies: 0Last Post: 09-11-2013, 09:59 PM -
Bought my first tractor Ford 1710 4x4
By CashMI in forum New Holland Owning/OperatingReplies: 23Last Post: 05-18-2013, 11:41 AM -
Brake repair on Ford 1710 tractor
By robbert in forum Parts/RepairsReplies: 3Last Post: 10-23-2010, 03:01 PM
