Hydraulic motor sizing/performance question
   / Hydraulic motor sizing/performance question #1
Jay4200
Hudson/Weare, NH
L4200GST w/ LA680 & BX2200D w/ LA211
I have no idea what the sizing spec of a hydraulic motor means, so please bear with me.
I want to use a hydraulic motor to rotate the chute on my snowblower. The cheapest high-torque / low-speed hydraulic motor I can find ($80) is a 2.5cu-in motor rated at 1115 RPM at 12GPM (2250psi). My tractor's hydraulics (BX2200) are somewhere in the 5.5-6 GPM range, and probably in the ballpark of 2000psi. If I hook up this motor to a 5.5 GPM source, will it turn at ~500RPM? What is the cu-in rating used for?
If anybody can point me to a site that explains the calculations for specifying a hydraulic motor, please do. I'm an electrical engineer, so the more technical the better. Thanks!
   / Hydraulic motor sizing/performance question #2
Flow = Speed.
Size of the motor and pressure determine the rotating torque.
The 2.5 cu in rating is how many cu in of fluid it takes to make 1 revolution.
So... 5.5gpm in. There are 231CI in each gallon of fluid. So you would be passing 1270 CI of fluid per minute through it. 1270/2.5 = 508RPM theoretical. That is not counting for efficency loss and assuming you actually will be getting 5.5GPM to the motor.
The way it is rated now, 1115rpm and 2.5 ci @12gpm....
12gpm is 2772 CI.
2772/2.5 = 1108RPM. So their rating is right on (+/- a little).
   / Hydraulic motor sizing/performance question #3
So, JAY, if you want low speed, then you need a large displacement motor, which can be several
times the cost of a low disp motor.
Or, you can use a cheaper motor and use sprockets & chains, or gears to slow things down.
Or, you can use a cylinder and leverage to rotate your shute, since you do not need full rotation.
At least one TBN member has done this, I can not remember who. In this case, a larger
diameter cyl will be slower, but you can slow it down with small hoses and even a restriction
orifice.
   / Hydraulic motor sizing/performance question #4
Surplus Center
Go left side, under hyd calculators, select motor speed and torque.
Your 2.5 motor using 5.5 GPM will turn at 508 rpm, 796 inlbs
   / Hydraulic motor sizing/performance question #5
Sooo, to reverse the math, that motor would turn your chute one complete revolution in just over a tenth of a second.
Might wanna find a slower way, or just use the CHUTE to throw the snow :=)
   / Hydraulic motor sizing/performance question #6
Why in the world would you want to use a hydraulic motor ... as opposed to a hydraulic cylinder ... to do chute rotation ?
   / Hydraulic motor sizing/performance question #7
with a hydrualic cylinder, you get in rather ugly spot to even be able to do a 180 degrees rotation.
   / Hydraulic motor sizing/performance question #8
small hyd motor you can get, with a adjustable hyd valve. seems a little costly....
why not a 12v electrical motor and a cheap 12v dip switch to adjust direction?
   / Hydraulic motor sizing/performance question #9
I'm using a hydraulic cylinder on my Buhler Farm King 60" blower and I have in excess of 180 degrees of rotation.
It's all in the mechanism (that the cylinder is acting on) that actually rotates the chute ... ;)
   / Hydraulic motor sizing/performance question #10
Yeah. And at about 60ftlb of torque. Gear it down to reasonable speed and EVEN MORE torque. Probably not a good plan to use a hyd motor.
