greendirt
I have a john deere 2040 with a open center hydtaulic system. All hydraulics stopped working. So far I have split the tractor and verified the trans pump is good, changed fluid with filter and cleaned suction screen. I replaced the main pump. The steering is working fine now. The lift will raise and lower but when in the up position hydraulic pressure does not relieve so I lower the lift. The lift also can not be raised part of the way up or down. It is either all the way up or all the way down.
