RAO490
I am a new member, I have visited the forum lots of times but never had to post a question. I will say there is unlimited amount of info and knowledge here and i would like to say thanks in advance to each and everyone involved. I have somewhat knowledge on the Ford 1000 series but no experience on the 10 series, I will also say i have a service repair manual in route. I just picked up a " what i believe to be " 1986 Ford 5610 ll, here is info on tractor.
Tractor #C760978
Mod. #LA414C
Unit #6E6E
Engine #6D9A
Trans. #6D09B
Rear axel #5M10B
Hyd. pump #6D2B
Hyd. lift #6C14B
The tractor is sound, solid and runs out very good. I need to add at least one remote valve on this tractor. It has had remotes in the past I suspect because of the type hose fittings in valve under the seat and those are plugged. After looking at dealer prices for valves and etc., there has to be other options. Could i tap in to pressure on valve under seat run line to remote with hook ups and a return back to sump or is this wishful thinking. Will the pressure,volume and what about heating of oil ? Does anyone know of a web site that would have good info on hydraulics for 5610 ? Any and all help would be appreciated. Thanks
Tractor #C760978
Mod. #LA414C
Unit #6E6E
Engine #6D9A
Trans. #6D09B
Rear axel #5M10B
Hyd. pump #6D2B
Hyd. lift #6C14B
