Peter755
Hi All,
I own a JD 755 with a JD Front loader (type 60, 70 or 70A - not exactly sure).
One of the bucket hydraulic cylinders were leaking profusely so I have bought two Nortrac hydraulic cylinders I want to put in instead - need a bit of mechanical adapting but fit nicely. The hydraulic inlets on the Nortrac cylinders are indicated as "Standard 3/8 inch NPT". The JD cylinder has smaller inlets though - I believe they are likely 1/4 inch, not sure though? Does anyone know if I can just use standard 1/4 inch to 3/8 inch conversion fittings? Are the JD hydraulic hose fittings special in any way?
Thank you very much
Peter
Thank you very much
Peter
