Yourkie
If you don't mind I like to run even relatively minor tractor repair jobs past others that may have had some experience, unless I've done it before, and in this case I have not. Replacing the leaking hydraulic hose seems like a straightforward deal. The leak hasn't busted out but it is leaking enough near the lower BH pivot point that it needs replaced and as the fluid will damage vegetation for starters. Actually I can't tell which bucket hose is leaking because the hoses are covered in nylon cover shields and the hose(s) that I suspect are the culprit go up through the boom to the bucket cylinder. I'll probably remove and replace both.
Planned Procedure: Extend both booms straight out and rest the bucket on a wood block for best access and to relieve pressure. Shut off engine and work controls to relieve hydraulic pressure on lines. Remove cable ties securing nylon sheaths. Remove the connectors and hose fittings at the cylinder and also at the pump end. Remove hoses and cover sheaths.
Is there a recommended way to remove these fittings as they have a locking nut and another hex fitting? Will the cylinders and pump end require that the openings be plugged with something i.e. stopper, cork etc to keep hydraulic fluid from siphoning or leaking out? Will the system purge itself of air once the new hose is reinstalled? Is a thread seal required on new fittings? Are new O-rings required or are these typically compression fittings? Is there a bleeder valve that must be opened to purge air? Appreciate any and all tips. I'm going to have these hoses made in a shop locally. I'll need to determine PSI. I would assume from nomenclature on original. Thanks.
