rasorbackq
Just bought a 4x8 trailer with a hydraulic power pack . The seller told me that the dump has problems to dump the load if the load is humped up at the front But if humped up at the rear will dump the load . He was using it to dump loom . So my question is what allows a dump to dump more weight? Is it the cylinder ? I look on line and see all the different sizes of cylinders. They all seem to have the same ratings only the lift lengths are different. If I remove the power pack and rehook to the tractor rear hydraulics will it be stronger?
Best I can tell its a hydro Tek single action . Not the exact unit but a little older Might even be a double action as it makes noise when lowering but don't think its hooked up to power down.
Overview
The single acting power pack can be used for many applications including Aerial Platforms, truck hoists, scissor lifts, compactors, factory automation etc.
Feature(s)
Integrated 12V DC 2-position solenoid directional control valve
Application(s)
Truck hoists, dump trailers, scissor lifts, aerial platforms
Attributes & Specifications
Type Single Acting
Relief Valve Setting 3,000 PSI
Relief Valve Range 1,000 - 3,000 PSI
Flow Rate @ 3,000 PSI .68 GPM
Port Size 6 ORBF
Reservoir Size 1 gal.
Remote Included Yes
Package Dimensions (L x W x H)
20.0 x 10.5 x 10.5 in.
Overview
Feature(s)
Application(s)
Type Single Acting
Port Size 6 ORBF
Remote Included Yes
