FEL 3rd function using diverter, QA lock and 4th function on Kubota L5030HSTC
   / FEL 3rd function using diverter, QA lock and 4th function on Kubota L5030HSTC #1
SweBota
Sweden
Kubota 5030HSTC, Husqvarna P525 & PF21 AWD
Finally made some progress on the third function today. I'm trying to use parts that I have already got lying around, but the need for different hydraulic adapters is always greater than the supply....
Anyway, 3rd function will be diverted from the curl circuit. The 6/2 diverter will be located on the right FEL frame, and I have just made a bracket to attach it to the existing pipe bracket, pictures tomorrow!
An additional 3/2 diverter will provide "3.5"-function to the Trima QA implement locking cylinder, soon to come: http://www.tractorbynet.com/forums/build-yourself/338095-l5030-trima-sms-quick-attach.html
A 4th function is also implemented by hoses that go down to the front 4pt hydraulics, normally used for the V-plow. As there is already a 12/2 diverter between the FEL and front hitch, i can activate this by a selector switch.
This is related to my other projects listed here: http://www.tractorbynet.com/forums/...bought-l5030hstc-post4148023.html#post4148023
Br / Marcus
Added a 6/2-diverter ( to the left in picture) in the curl circuit, after the self-leveling valve.
/Marcus
1999 Toyota Camry XLE Sedan (A50324)
1999 Toyota Camry...
2013 International DuraStar 4400 Altec AM547 50FT Material Handling Insulated Forestry Bucket Truck (A51692)
2013 International...
COOPER LIGHTING CAT. NO. MHEP-22/28-175-MT (A52748)
COOPER LIGHTING...
2023 Polaris Sportsman 570 AWD ATV (A50324)
2023 Polaris...
2012 JACK COUNTY 130BBL VACUUM TRAILER (A52472)
2012 JACK COUNTY...
2003 Lincoln LS (A50324)
2003 Lincoln LS...
