jonix
Hi,
"Originally Posted by jonix"
"Sorry to use your post to try to solve my problem , but I'm desperately in need of help. I am in the final phase of a firewood processor ( 3D images ) , and the first tests did not go well. The two 50 lts/min (13.2GPM) and 66 lts/min (17.4 GPM) gear pumps exceed 5000 PSI (!!!!) and still not achieve the 10 cm (3.9" that should develop 30.4 tons @ 5000 PSI) (how do you get this result?!) diameter piston to split eucalyptus with a 400 mm (15.75") diameter into my 8 edges knife ..can anyone help me with this? (a picture of the splitter cylinder and wedge would be helpful) (in the end i post a youtube link to a walk around video, and a jpg with the hydraulic circuit, the only thing i donエt know is the valve types that iエve got there)
And why the F11-005 PARKER (.305 CI / revolution) motor with 34 Lts/min (8.98 GPM) dedicated pump can not get a decent cut at 150 bar (2,175 PSI)? ( a 3/8 pitch chain with a 7 teeth sprocket and a set of pulleys to double speed).. (Saw motor should run at 7200 RPM with the given information developing 100 in/lb of torque and 5.7 HP. Chain should run at 3150 ft/min)
The system has a 18 KW (24 Hp) electric three phase motor with 4 pumps (2 for splitting, 1 for the saw and saw piston, and 1 for log conveyor, log feeder, clamp, log lenght stopper, etc...) what is wrong with this? something has to be wrong... (Need information about how the two pumps are used for splitting)
I can get you much more information and a video of what is happen (all the machine is near to break and still not splitting the wood!!!) if you need/want to see that...
thanks in advance..and i hope anyone helps me, because here in portugal the season is about to begin, and i have no firewood drying..."
I made notes in red. Changed units for those of us not used to metric (thanks, my drawing as already almost converted units). I would say that we really need information about how the two pumps are used to split. We need pictures of the wedge to see how the log will spread out as it is split. Is the wood green or is it dried out? I read that eucalyptus is more difficult to split when dry. (Yes, dry eucaliptus is much more difficult to split, even so i think it should be splitting easly...)
Off hand I would think the splitter would work at 30 tons but (i think i was tell that at 3000 psi it would be working with 40 Tons) it all might depend on the wedge design (yes, the wedge is not totally staggered [thanks SpringHollow], you can see it in the video). Also if there is anything binding (what is binding? canエt find a translated word for portuguese) in the splitter travel (i donエt think so, it is only bending when the logs stop because is not being splitted).
The saw seems a bit slow to me (I made an excel sheet about this calculations, but our results arenエt the same - i can say i trust more in yours
. You have decent torque but I would think you'd want your chain speed to be around 5000 ft/min. It could be as simple as changing to an 11 tooth sprocket if one is available (yes, iエm already waiting for one with 12 tooth).
My previous comments still stand, I would gather additional information and start a new thread for this in the hydraulics or build it yourself section. Feel free to post a link to it here if you wish (thanks again, i would do that).
Youtube video walk around (sorry, i wasnエt able to film the processor at working, i will try to do it soon)
https://www.youtube.com/watch?v=qFU2Qhwh5Ak
and hydraulic circuit (i think it is all in there)...
thanks again for your help, and hope i could find what is wrong with it..
