FORD 1841 INDUSTRIAL POWER STEERING
   / FORD 1841 INDUSTRIAL POWER STEERING #1
COASTBUSTER
Member
SHIRLEY,NY
4000 hd industrial 1964
Had pump rebuilt. Took apart control valve under steering wheel. Found 2 broken in half centering springs between plungers. Replaced with new. Now steering turns fine to left but no power to right. This control valve has 4 plungers with 2 centering springs and 2 plungers with ball bearing which is I'm assuming,a check valve.This tractor has only 1 steering cylinder mounted between the front wheels. Any ideas would be appreciated. Dan
After writing this post I went out and disassembled the control valve. With help from a friend discovered that the top bearing and races were upside down causing the right turn to hit the steering post case. Flipped them over and now have steering to the right. So basically the 2 broken centering springs was the trouble all along. Anyone trying this repair should carefully note how the parts are fitted as well as take pictures of every step. Thanks to all who read this post even though there were no replies. Dan
2003 Paris Utility Trailer (A52377)
2003 Paris Utility...
2025 Wolverine EX-66-84L Pallet Fork Extensions (A53117)
2025 Wolverine...
2025 SDLANCH SDLGC80 UNUSED Electric Golf Cart (A53117)
2025 SDLANCH...
PALLET OF SCAFFOLDING PARTS (A52706)
PALLET OF...
2018 Suzuki KingQuad 750 AXi 4x4 ATV (A51691)
2018 Suzuki...
