FEL seems weak- how to check
   / FEL seems weak- how to check #1
RandyHut
Member
Piqua, OH
Mahindra 2816
I have a 2011 Mahindra 2816 gear machine with 111 hrs. The FEL seems weak and while dumping the bucket it gets to a point and seems to slow down then goes ahead and dumps the rest of the way. If i try to pick up a whole bucket of gravel from a pile it just doesn't seam to want to pick it up if i get into the pile to far. How can it be checked? It will pick up a whole bucket, it just seems slow doing it.
Thanks
Randy
   / FEL seems weak- how to check #2
Get a pressure gauge on it. < $65
Search here.
/edit - you need to check out the size and type of your fittings to make sure they hook up properly. For example my B7610 uses a different size than my M4700.
   / FEL seems weak- how to check #4
For a quick check unhook and then rehook all the quick dissconects. Make sure the linkage is oiled and working properly.
   / FEL seems weak- how to check #5
The way you describe the dump, sounds like you aren't using regen dumping a loaded bucket, gravity is dumping too fast and pulling in air. Once the bucket reached the point gravity isn't trying to dump anymore, it pauses while the cylinder refills with oil and pushes the air out.
Not being able to lift out of a pile can all be in technique. Digging deep into the bottom of a pile and trying to lift, you are trying to lift way more than just what's in the bucket.
To verify...pressure guage will show. But I am betting it ain't your issue.
   / FEL seems weak- how to check #6
A tractor can't stab in a pile and just lift it up. The only accurate way is to check the pressure.
   / FEL seems weak- how to check #7
The pressure guage seems like the way to go. What occurred to me is to measure out the maximum weight your loader is meant to lift, place it in the bucket and try to lift it. This probably wouldn't be completely accurate if the rating is specified at the pins but it should be close.
   / FEL seems weak- how to check #8
Unless you are using lead the bucket won't hold enough material to reach maximum capacity.
   / FEL seems weak- how to check #9
And max capacity is to max height. You can lift alot more than that at ground level
   / FEL seems weak- how to check #10
And max capacity is to max height. You can lift alot more than that AR ground level
Okayeeeee what has essentially changed? Seems to me that the Foot-lbs equation would be that the lbs were the same but from a foot standpoint, the moment of inertia would be a lot longer theoretically if the arms were straight out vs being almost vertical. At 90 degrees the feet would be about zero where at 0 degrees they would be at a max.
Case 621D (A57148)
Case 621D (A57148)
NEW Fork Extensions (A59000)
NEW Fork...
Skid Steer Concrete Mixing Bucket (New/Unused) (A59225)
Skid Steer...
CAT 289D3 (A58214)
CAT 289D3 (A58214)
2012 International Derrick Digger (A55973)
2012 International...
LOT: Fuel Transfer Tank, Tool Box, 12 Volt Fill-Rite Pump (A59076)
LOT: Fuel Transfer...
