LD1
Epic Contributor
Got a brand joystick valve, having the same issues GPinthemitten had in this thread http://www.tractorbynet.com/forums/hydraulics/344932-loader-valve-curl-function-diagnosis-9.html
Got this valve to install on dads IH444 and 2000 loader. It seams either the directions are just plain wrong or inclompete in switching from A to A1 configuration. Here is the complete PDF and where I got the following instructions and pictures from https://www.surpluscenter.com/_MoreSpecs/i9-7401.pdf
Here is what they show:
Which clearly shows that you can have A configuration with hoses coming out the left, or A1 with hoses coming out the right. We need to mount in A1 configuration.
So follow the directions and picture as follows:
The result is NOT what A1 illustrates....in a way.
If you look at the first picture, notice that they are changing the hoses. IE: the hoses labeled for boom lift have now switched to the OTHER spool. In the "A" configuration, the bucket hoses were hook on the side of the valve nearest the inlet and PRV, in the A1 config, these are now the boom hoses?? (Mentally rotate the left image in your head and then compare to the image on the right....notice the hose locations changed)
Its not so simple just to swap hoses, since one spool has a detent-float and the other spool has regen. These are a function of the spool, NOT the joystick. So no matter how the joystick is attached, the spool with float HAS to be boom, and the one with regen HAS to be bucket dump. So something is wrong here.
SO, we established that we CANNOT simply swap hoses as directions show, since that would put float detent on the dump circuit, and regen on boom lower.
So looking at it as hooked up in A1 config as per drawing, if we orient the valve with the hoses coming out of the TOP, that puts the detent for float and boom raise in the correct location, But now the curl and regen are backwards. With hoses coming out the top, pulling the valve to the left is now regen, which should be curl.
One of the reasons I suspected perhaps A1 config would be just 90 degrees off of "A" config instead of a full 180 degree swap is because of this line in the instructions:
So what is the rod end retainer plate and corresponding flat?
If I were to assemble as per the drawing, and orient that to the left, that would put the hoses facing the front, NOT to the right as pictured in the very first picture?
It would seam that there is no possible way to orient this valve other than A configuration unless you want to relearn how to use a joystick. Cause in A1, nothing seems to make it work.
Now to the part about directions being wrong and possibly "incomplete". Is it possible to swap the two spools? I know its alot of work, but in A1 config and hoses out the right side as the illustration shows, moving the joystick fore and aft operates the spool that has regen, and moving it left to right operates the spool with the float detent. If the casting is the same, and the spool assembly is the only differences, perhaps they need swapped.
Both float and regen are accomplished by pressing IN the respective spool. So forward is currently regen and right is currently float. Swapping spools would swap those functions and be correct, if thats possible.
Hope I didnt lose anyone. These seem to be pretty popular valves. As the tile asks, anyone change from A to A1 successfully? Or does everyone just mount in A config? If I can get A1 to work, its a whole lot simpler given where the IN, out, and PB need to hook to the tractor at, and easier to mount on the bracket thats already welded on there.
