kruszert
I have a Jinma chipper which has mechanical feed. The feed system is the weak link on this chipper IMO. I just broke the third gearbox after 1 hour chipping - - four inch max branches. At $200 per gearbox I need to do something else! I would like to drive the feed drum using a hydraulic motor. Some of the more expensive chippers use a hydraulic motor feed systems for both a top and bottom feed roller but I will settle for just driving the one drum.
I am hoping to use the hydraulics from my tractor - - I have an extra line not being used. The tractor hydraulic output is 12.5 gpm at 2300 psi. Problem is I need to go slow - - the drum turns around 13.5 rpm. I can stand a little slower but no faster. When I look through the motors (Surplus Center Cat.) they will all go way too fast unless I have some way of reducing flow and most are not rated for the PSI of my system. They do sell adjustable flow controllers but I would have to really limit the flow to get down to the required RPM. I am not even sure if this is good for the motor.
I am not new to building stuff and have set up hydraulic cylinders for a stump grinder but I have never worked with a hydraulic motor. Suggestions would be greatly appreciated.
Thanks,
Reggie
(and yes I know you get what you pay for and on this occasion I am regretting not spending the extra money to get a better chipper)
Thanks,
Reggie
