Stampeder
Gold Member
- Joined
- Dec 2, 2006
- Messages
- 318
- Location
- East Texas
- Tractor
- Montana 4940C, FEL, Quick change 3 point factory hitch, pallet forks, grapple, 50 gal tank sprayer, Bush Hog PHD
My Montana 4940C has the WV300 (I believe) Nimco control with the CV432 valve.
When I push the control lever forward the FEL will lower but when I pull the control back there is no resistance like it normally should and the FEL will not raise. The bucket tilt works just fine in both directions
I'm not sure if this is a symptom of a broken cable or if it is more to do with the control valve. Hydraulic fluid level is just fine. And is clean.
Is this a common failure mode for the Nimco controls?
Considering I've had the tractor for 10 years and this is the first problem with the hydraulics other than one hose leak, I think I've done pretty well.
Any thoughts?
Thanks.
Glenn.
Any thoughts?
Thanks.
Glenn.
