ATM73
I recently picked up a Montana 4340 with FEL, but someone has installed a two handle valve on the loader. I picked up a joystick valve from Brand . My question is, on the current setup, there are three hoses besides the four that power the cylinders. Two are attached on the "in" side of the valve, and one on the "out". The two on the "in" side are attached to a block, one opening labeled "P" (which I assume is Pump), the other "T" (which I assume is tank). Where on the new joystick valve should I attach the two hoses labeled "P" and "T"? Should I just open another port on the "in" side of the valve, or do I need to add a Tee. Thanks in advance for your help!
- New Valve
- Current Setup
- New Valve
- Current Setup
