borisvonf
Member
- Joined
- Mar 16, 2010
- Messages
- 45
- Location
- Greenville SC
- Tractor
- Jd 5500 mfwd. Kawasaki mule sx 4x4 JD5103 with 521 loader
Hello brain trust
I borrowed my dads Jd 5210 with loader to work on my farm.
For some time I had noticed lack of power such as not being able to go uphill in C 1 and not able to get to full speed on flat ground in highway gear C3. Issue got progressively worse over last 2 weeks.
Initially, my thought was air or fuel issue.
Cleaned air filter and changed fuel filter. Spend 1/2 a day priming fuel system, checking flow to all fuel components and venting air from all lines but would lose power and shut down still.
Finally decided to remove loader and take to dealer on trailer for suspected injector pump issue.
Once loader removed, machine ran like a champ. Good power. Maintained rpm. Ran for an hour doing misc farm work.
Reconnected loader and lost power again but able to get back into shop and parked.
Now my thought is loader hydros.
Loader still works.
Loader valve has 2 lines coming in then splits to 2 valves lift and curl functions and has float on lift.
Any suggestions? Thanks in advance for any help.
Loader still works.
