I have a snowblower with hydraulic chute rotation and hydraulic deflector. As the motor that rotates the chute is fixed on the frame, the motor's unprotected hydraulic hoses just sit there . Admittedly there is probably some vibration and some slight change when the snowblower is lifted that I have decided to tolerate. The piston that actuates the deflector, however, is rotated with the chute, and the piston's hoses are moved quite a bit. My first concern was that the hoses might get caught between the frame and the toothed flange of the chute and damaged. Installing some sort of wand and spring device to support and route the hoses seemed like too much trouble. I fabricated a "railing" to prevent the hoses from drooping into dangerous areas. I then wrapped the hoses with hard plastic spiral covers to guard against chafing on the rail. So far, three winters, no problems.
The protectors were described by i.d., and your hoses have an o.d. larger than their nominal size; measure. I bought the protectors on the net after finding considerable variation in price. Look at similar spiral wraps for electrical or computer cables. I went cheap; part of the savings was probably the supplier sending only an e-mail invoice that I can no longer find and using plain cardboard boxes, so I cannot provide a source name.
Captain Dirty
