Page 1 of 3 123 LastLast
Results 1 to 10 of 25
  1. #1
    Veteran Member npalen's Avatar
    Join Date
    Nov 2009
    Posts
    1,276
    Beloit, KS
    Kubota B9200 HSTD and New Holland TC29DA
    Default "Hydraulic Thread" Can Someone Identify This?
    I was hoping that the term "hydraulic thread" would catch your attention and you can help me out here.
    I'm wanting to check the relief valve setting on the 3PH (three point hitch) on my kubota B9200 HST-D. I need to make a bolt similar to that shown in the photo in order to perform step 2 shown in the print. The bolt shown attaches the banjo fitting to what I believe is the return port on the 3PH valve. The new bolt for testing would be similar except no cross drilling and a 1/4" NPT port on the end to attach the pressure gauge.
    I had planned to lathe the single point thread that I thought was a metric pitch but it appears to be a really odd pitch. Here are the measurements I come up with: The pitch appears to be about 1.38mm or .054" or 18.5 TPI and the diameter measures 0.645" (16.4mm)
    Using thread pitch gauges it shows between 18 and 20 TPI (threads per inch) and about .054" pitch and about 1.38mm pitch. Weird! The note in figure 3 (screw size PS 3/8") throws me also. Is that some kind of 3/8" pipe thread for attaching the test hose with gauge?
    I'm guessing that Kubota makes this odd thread so that a dealer has to buy their special fitting. Maybe someone with inside knowledge can hopefully shed some light on this.
    Attached Thumbnails Attached Thumbnails "Hydraulic Thread" Can Someone Identify This?-bolt-hyd-1-jpg
    [SIGPIC][/SIGPIC] Palen Archtops at http://guitarsnjazz.com/
  2. #2
    Epic Contributor k0ua's Avatar
    Join Date
    Jun 2009
    Posts
    25,648
    Branson, Mo.
    Kioti DK35se Hydrostat
    Default Re: "Hydraulic Thread" Can Someone Identify This?
    You got my attention, and wish I could help... but sadly I cannot..
    James K0UA
    Kioti DK35se hydrostat with 2 QA buckets, 48 inch. King Kutter Rotary Cutter. 750 lbs ballast box. Loaded tires, Construction Attachments SSQA Lightweight Pallet forks. EA 50 inch single lid "wicked" Grapple. Satisfied Everlast PA160 welder owner NRA Life Member How to add a link to a post . Best way to search TBN .
  3. #3
    Elite Member 4570Man's Avatar
    Join Date
    Apr 2015
    Posts
    4,225
    Crossville, TN
    Kubota L3240, Kubota B7100, Kubota F2560, John Deer, F525 Mule 600
    Default
    Is there any other location to check it? How much is a new piece? It might be easier to buy another one and modify it.
  4. #4
    Join Date
    Nov 2009
    Posts
    1,276
    Beloit, KS
    I'm thinking perhaps plugging the cross hole with a piece of pressed in brass rod. Then drilling from the head end thru at about 1/8" diameter, then drilling and tapping a 1/4" NPT thread for the pressure gauge rather than making a new bolt. Then the brass plug could be punched out after getting the pressure readings.
  5. #5
    Join Date
    Mar 2009
    Posts
    222
    As you probably already know metric uses mm/thread to designate pitch. 1.5 mm/thread is common for fittings.
    Older Japanese equipment turns up with BSPP sometimes. 3/8-19 turns out to have a 0.656" OD and 19 TPI. Sounds like what you have.
    ISZ
  6. #6
    Join Date
    Nov 2009
    Posts
    1,276
    Beloit, KS
    British Standard Pipe Thread Chart
    I'll bet you're right. I found this chart which shows a 3/8"-19. My Bota is a 1987. Seems strange that Japan used British thread standards rather than metric but I'm sure there is a logical explanation.
    My lathe will cut 18 or 20 pitch but not 19.
  7. #7
    Super Star Member LD1's Avatar
    Join Date
    Apr 2008
    Posts
    16,504
    Central Ohio
    Kubota MX5100
    9035-06-04
    Type that into the search box at discounthydraulic hose.com
    Or 9035-06-02 if your gauge is 1/8npt instead of 1/4
    ".........there is only one way to find out."
    "Ok, hold my beer and watch this.........."
    MX5100 DIY Remotes
    MX5100 Diverter install
    Front Snow Plow Install
    Ford 5500 Backhoe
    Kubota MX5100HST w/LA844
    2005 Dodge 3500 4x4 Diesel
    8N Rebuilt and restored
    Bushhog 306
    3 Homemade wood hauling trailers
    Dolmar 6400 84cc ported
    Sachs-Dolmar 120SI Ported
    (4) Sachs-Dolmar 116SI Ported
    Dolmar PS540
    Sachs-Dolmar 115i
    Sachs-Dolmar 117
    Sachs-Dolmar 112
  8. #8
    Join Date
    Nov 2009
    Posts
    1,276
    Beloit, KS
    Quote Originally Posted by LD1 View Post
    9035-06-04
    How does the BSPP thread seal?
  9. #9
    Join Date
    Apr 2008
    Posts
    16,504
    Central Ohio
    Kubota MX5100
    With a flat copper washer, bonded sealing ring, or o-ring
    MX5100 DIY Remotes
    Ford 5500 Backhoe
    Bushhog 306
    Dolmar PS540
    Sachs-Dolmar 115i
    Sachs-Dolmar 117
    Sachs-Dolmar 112
  10. #10
    Join Date
    Nov 2009
    Posts
    1,276
    Beloit, KS
    Thanks! Great information!
Similar Threads
  1. QUESTION: Identify this "adjustment" screw ???
    By TSO in forum Owning/Operating
    Last Post: 01-07-2015, 12:16 PM
  2. Replies: 5
    Last Post: 04-01-2014, 12:00 PM
  3. Replies: 0
    Last Post: 02-08-2011, 01:46 PM
  4. Replies: 5
    Last Post: 01-21-2010, 08:11 AM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2017 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
