szzuf
- Joined
- Jan 28, 2017
- Messages
- 10
- Location
- Killdeer Sask
- Tractor
- Terex 51-19 Telehandler Gehl 4640 Skid Steer
I am a barb wire fence contractor. I would like to build a wire unroller to put out new wire but be able to tension it at the same time. The design of the unroller will be mounted to the front of a skid steer. Up to four rolls of wire placed vertically with the wire running through and around a few rollers mounted vertically to create drag and tension on the wire. One of the rollers I would like to turn an orbit motor or hydraulic pump that would flow through a flow control valve that I could dial down to create my braking system.
I've got the idea but haven't started the trials to see if it would work. I was wondering what you guys thought of the idea?
There is one unroller on the market. Stretch-N-Go Hog | EZG Manufacturing As far as I can tell though they use a disc brake system to create tension on the wire.
