Page 1 of 2 12 LastLast
Results 1 to 10 of 12
  1. #1
    New Member
    Join Date
    Sep 2007
    Posts
    14
    Alexandria Twp, NJ
    Kubota L245DT
    Default Need a solution for a worn pto splined shaft/female coupler for KUBOTA L245DT FEL
    Looking for solutions to a worn pto splined shaft/female coupler for kubota L245DT FEL. Part has been discontinued by Kubota. HELP!
    See attached photo's
    Attached Thumbnails Attached Thumbnails Need a solution for a worn pto splined shaft/female coupler for KUBOTA L245DT FEL-img_1512-jpg   Need a solution for a worn pto splined shaft/female coupler for KUBOTA L245DT FEL-img_1516-jpg   Need a solution for a worn pto splined shaft/female coupler for KUBOTA L245DT FEL-img_1518-jpg   Need a solution for a worn pto splined shaft/female coupler for KUBOTA L245DT FEL-img_1520-jpg
    Thanks,
    Tactorbill
  2. #2
    Join Date
    Dec 2013
    Posts
    1,671
    Southern Alberta, Canada
    4410 and F-935 John Deere, MF 245
    Default Re: Need a solution for a worn pto splined shaft/female coupler for KUBOTA L245DT FEL
    In the first picture, what is behind the pulley? Are you able to remove the shaft in the center of the pulley with the worn splines?
    Edit to add: If you can remove the shaft and have it machined round with a keyway so that you can use a chain and sprockets like in the third picture. Can you get a browning hub with splines like that and JB weld it on to the shaft?
  3. #3
    Gold Member
    Join Date
    Apr 2011
    Posts
    495
    Jackson, NY
    none
    In the first picture, is that shaft coming out of the transmission or is it a short shaft? If it's coming out of the transmission I would think you will have to replace it, or take it out and get it machined with a key way? Either way it isn't going to be any fun. Good luck, hopefully someone has an easy solution for you.
  4. #4
    Super Member s219's Avatar
    Join Date
    Dec 2011
    Posts
    6,026
    Virginia USA
    Kubota L3200 Deere X380 Kubota RTV-X
    If that joint needs to have some slop, for the two parts to slide a little, then that really limits your options.
  5. #5
    Platinum Member airbiscuit's Avatar
    Join Date
    Aug 2004
    Posts
    627
    Wisconsin
    New Holland T2310, New Holland TC21DA, Farmall H *** Previously - 1941 John Deere B, Shibaura 1500, John Deere 850, Bobcat 642, New Holland 1925
    Quote Originally Posted by s219 View Post
    You might be able to fab something up starting with a PTO overrunning coupler if you can find one with the right splines.
  6. #6
    Join Date
    May 2011
    Posts
    599
    NKY
    Yanmar YM186d,John Deere 1050, Case 211B
    Quote Originally Posted by davedj1 View Post
    That shaft is the front of the engine crankshaft. All one piece.
    JD1050,YM186D,Case211B,Homemade- sawmill & log splitter & log hauling arch trailer
    JD14T,Ford 532 balers,
    AC 80-R3,Ford 501 sickle mowers
    2.1 KW Off-grid Solar System and growing
  7. #7
    Join Date
    Oct 2010
    Posts
    664
    Well that sucks.
    Wonder if you could find something similar to this lovejoy coupling, splined couplers - Google Search , once it's installed and tight, plug weld it to the end of the crank (use s/s) and make sure the ground is on the coupling when you weld it.............Mike
  8. #8
    Veteran Member CCWKen's Avatar
    Join Date
    Mar 2005
    Posts
    1,163
    South Texas, USA
    Ford-3910, JD-420C, Kenbota-Custom, IH-2606
    Does that shaft drive a pump? You let the maintenance go too long. That chain coupling is also worn and probably caused the wear on the shaft. If that's the nose of the crankshaft, you may have to change the way the (pump) shaft is driven or pull the crankshaft for machining. A new spine end can be made for the crank. The only alternative is to cut the spine off the crank and use the pulley to drive the shaft. But the pulley may have to be removed too so it can be drilled to center the new drive shaft.
    Pulley drive adaptors are available similar to the one shown in this photo:
    Need a solution for a worn pto splined shaft/female coupler for KUBOTA L245DT FEL-ford_adaptor_and_shaft_on_d-17_front_pulley_medium-jpg
  9. #9
    Elite Member
    Join Date
    Sep 2007
    Posts
    3,209
    Doniphan, Mo.
    Kubota L4240, B7800 & BX2660
    What is the spline count on yours and the OD? By your picture it looks like someone welded it to the pulley. I have a fitting that bolts to the pulley with 3 or 4 bolts and some other shafts. I could not find yours in the parts manual for your tractor. I forgot to look today to see what I had for sure.
  10. #10
    Join Date
    Dec 2011
    Posts
    707
    Western Washington USA
    MM UTS and Homemade
    If those splines are on the crankshaft you can probably cut the diameter down so you can slip a new hollow splined shaft on and weld the end. Can you run the engine the way it is? If so I would idle the engine and use an angle grinder to grind the shaft down carefully to a standard size small enough so a new splined shaft will have enough wall thickness to be strong enough. You'll have to use a micrometer with the engine stopped to sneak up on the finished size. A file held against the spinning shaft should take off the last little bit. Leave a chamfer on the end for welding.
    You'll have to use a lathe to drill a hole in the splined shaft so it doesn't wobble.
    If this won't work it seems like you'll have to pull the crank out and have it machined.
Similar Threads
  1. Need Shaft Assy for FEL - L245DT
    By Tractorbill in forum Parts/Repairs
    Last Post: 02-12-2017, 08:32 AM
  2. Replies: 23
    Last Post: 12-26-2015, 12:29 AM
  3. Replies: 36
    Last Post: 01-27-2014, 11:55 AM
  4. PTO Shaft Adapter 1 3/8 21 female to 1 3/4 20 male
    By mchildress in forum John Deere Owning/Operating
    Last Post: 07-19-2011, 01:30 AM
  5. Size of L245DT front PTO shaft?
    By realtaildragger in forum Kubota Owning/Operating
    Last Post: 03-26-2005, 01:52 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2017 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
