Tarakai
Hi I have acquired a grey import F37D with no manual. I have dropped the front axle oil ( looks like UHT rather than 90 weight gear oil) and was wondering how you fill the with new fluid as there are only three drain points. There does not seem to be any fill points unless you undo the top plates that link to the tie rod on both sides.
These drain points are obviously the rear facing drain points at the base of the knuckles on both the LH side and the RH side and a point 2 inches or so up the centre diff plate.
I have seen a thread somewhere where someone said the front Axle is lubricated via a tube that links through to the main hydraulic/ transmission and that it is not a separate system running on 90 gear oil. Can anyone shed some light on this. Without a manual it's not so easy. . Thank you Phil
