truckinfouble
I am eventually building or buying a 60" Brush Cutter for my Mahindra 4540. Don't worry, there will be extensive safety cage work done lol. That being said I need to build a Hydraulic Power Unit for my 3 point to power the cutter since my tractor system would be insufficient. My big question is, while there are many motor options for low flow 16-21 GPM range, and Prince makes a pump that makes 21 GPM @ 2000 psi using the 32 PTO hp my tractor has available, are there any other pumps with a higher PSI or hydraulic motors that are up to mower work at the 2000 psi range? Most commercial mowers I see, even the low flow, still seem to need 3000 psi.
