FTG-05
Elite Member
- Joined
- Jan 7, 2011
- Messages
- 2,588
- Location
- TN
- Tractor
- Kubota L4330 GST w/FEL, Kubota RTV-XG850, Kubota ZD326S
I have a fairly bad leak in my RR 3 spool Chief valve i got from Baileys last year. I *believe* it's the same valve that LD1 used for his RR as well (since I pretty much copied/stole his parts list for my RR, but I digress...).
In the first pic, you can see the first two spools (driver's side, towards the seat or to the right in the pics) and their hex head fasteners and how much I've tightened them. I tightened them several times and I am no longer comfortable tightening them anymore. Look at the screw heads, you can see they've been turned about 1/2 turn or maybe a little more. When running and hot, I'm getting a pretty good drip cycle (several per minute?; it's very noticeable). When cold and at idle, I'm getting maybe one/20-30 seconds or so.
And in this pic, you can see the oil dripping off the spools off the two inside spools.
Since more bolt tightening is out, what's the next step? I have never opened up one of these valves and have no idea what I'm in for; so please little words and perhaps crayons, if you would.
Thanks!
ETA: It's Baileys Chief G Series valve, part #220959: Shopping
Thanks!
