Re: Ezee On loader on MF 135 tractor
Hey all: I am one to be puzzled, but not one to give up. I have given up on posting photos as I have very limited computer skills, lots of time no results. To progress: Nimco informed me some time ago this valve does not have PB. I got a different shop manual a week ago that told me one should synchronize the pump linkage to the controls after pulling the transmission cover. When I attempted to do that yesterday the handle on the diverter became frozen and the pump began knocking. I am going to a MF dealer tomorrow and get the valve they sell to 135 owners and I hope that is the answer (this valve has return and supply both to the valve). The valve I installed is supply only and becomes extremely hard to move with the tractor running. I had tapped a return in the top of the transmission and it has never functioned right; I suspect the oil is in the diverter but stuck there.
I used compressed air to test the FEL valve yesterday and figured out what joystick position affects which port and actually switched two hoses from the probable wrong locations. I plan to install it and synchronize the linkage this week. I appreciate your input but if I can't get it I will probably seek a professional.
Thanks all of you.
Thanks all of you.
