Hello everyone
I am hoping someone can help with this seemingly over my head issue. I just purchased a chief p-80 series valve for a brush grapple I have just made.
1. It has the T port blocked off from factory and says this is correct for double acting cylinder use, is this correct
2. It has a N port right next to the t port. can this port be used for return to tank? and what is the N port?
3. can I safely tap into a return line coming from the loader valve already in use? not at the valve but 5' away before it returns into the tank, figured if is so I will just put a Tee in this line and tap into it.
tractor is a Mitsubishi 3250 FD with the V3 loader already added. Thank you in advance for any help on this?
