Page 3 of 3 FirstFirst 123
Results 21 to 25 of 25
  1. #21
    Super Star Member
    Join Date
    Mar 2008
    Posts
    15,066
    Northern Fingerlakes region of NY, USA
    Kubota L3830GST, B7500HST, BX2660
    Default Re: Hose Extension Leaks
    I would agree with Marc on the oring being needed, you can see the beveled spot on the female side and from what I can see under the copper crush washer, the male side looks like it has a place for the oring to go.
    Aaron Z
    A human being should be able to change a diaper, plan an invasion, butcher a hog, conn a ship, design a building, write a sonnet, balance accounts, build a wall, set a bone, comfort the dying, take orders, give orders, cooperate, act alone, solve equations, analyze a new problem, pitch manure, program a computer, cook a tasty meal, fight efficiently, die gallantly. Specialization is for insects.
    Robert Heinlein, Time Enough for Love
  2. #22
    Platinum Member TerryR's Avatar
    Join Date
    Jan 2009
    Posts
    565
    Boone, NC
    JD 870
    Someone had earlier suggested o-rings but I was concerned that without restraint around the outside of them they would not withstand the pressure and work out of the joints. These seals solve that problem by incorporating a steel ring around the outside of the o-ring. See Bonded Seal (Buna) for BSP and Metric Threads
    Terry
    JD 870, JD 404 loader, Bear Cat 73454 chipper, Bush Hog SQ60 rotary cutter, Bush Hog RTS62 tiller, Bush Hog 60-06 rear blade, Trac Vac model 854 pto leaf vac, single bottom plow
  3. #23
    Super Star Member
    Join Date
    Mar 2008
    Posts
    15,066
    Quote Originally Posted by TerryR View Post
    To me, your picture appears to be a textbook example of an ORB fitting:
    Hose Extension Leaks-orbpicture-png
    Source: http://www.discounthydraulichose.com...read_guide.pdf
    Aaron Z
  4. #24
    Join Date
    Jan 2009
    Posts
    565
    Boone, NC
    JD 870
    Quote Originally Posted by aczlan View Post
    To me, your picture appears to be a textbook example of an ORB fitting:Aaron Z
    Yes, that's what it looks like. Both the dealer and Marc recommended the bonded seal and I now have them. Now I'm waiting on some weather warm enough to get outside and test them. The issue isn't urgent enough to go out in 20 degree temps to install and test them.
    Terry
  5. #25
    Join Date
    Jan 2009
    Posts
    565
    Boone, NC
    JD 870
    It finally got a bit above freezing and the barn got warm enough to work in so I installed the bonded seals and gave them a brief test. I didn't try them in the field but did exercise the cylinders a few times and found no sign of leaks. So it's looking good.
    These things are not really o-rings as I know them -- the "ring" is not circular in cross-section but looks more like rounded capital "T". The thin inner part of the rubber has a pretty small diameter op - you have to screw it on the threads. I suppose that's to make sure it centers in the fitting so the actual seal area is properly seated.
    Anyway, it seems to do the job. Thanks Marc.
    Terry
Similar Threads
  1. Brand new XJ2025h and already have a cut hose and hyd leaks?????
    By cvcman in forum LS Tractor Owning/Operating
    Last Post: 07-12-2017, 07:51 PM
  2. Replies: 5
    Last Post: 10-07-2012, 05:10 PM
  3. Hydraulic extension hose
    By expedoman55 in forum New Holland Owning/Operating
    Last Post: 07-19-2011, 03:14 PM
  4. air in extension hose?
    By RandyK in forum Hydraulics
    Last Post: 08-23-2007, 09:57 AM
  5. Underground hose extension
    By Michigan_Mike in forum Projects
    Last Post: 04-25-2005, 10:23 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2017 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
