ssbogger
Just got my third function kit from Everything Attachments and am having some installation difficulties. I'll admit, I'm not a hydraulic guru but I do feel that I can read a set of instructions and turn a wrench. I've spent the past two hours searching this forum, google, youtube, etc. On to my issues...
1. I can not figure out what the loader valve is. Is it the one with the joystick and 4 hoses that go to the FEL attached to it or the one mounted below the floor board. (see pictures)
2. Which port on the valve below the floor board is the power beyond port? The three ports with hoses coming out of them going to the joystick valve are labeled "T", "R", and "P2".
3. Did I mount the WR Long assembly in the correct location? This is the only location I can find that it will mount with mounting bracket provided. When mounted in this location the hose supplied will not reach the valve below the floor board where I am supposed to connect it.
I may be missing something obvious. PLEASE HELP!
Thanks in advance.
Thanks in advance.
