Hilbilly
I've been in the process of converting my 3pth snow blower to hydraulic so I can run it on the Bobcat. I got the pump mounted on the blower with direct drive and put the blower in the SS snow bucket to see if it would work. It did but not well. So I did some checking and I think I have a pressure relief valve issue with the SS. I put a hose between the auxiliary out and in ports with a pressure gauge on the line. I'm getting about 600 psi in that line at full throttle. According to the service manual it should be 3000 psi. Also according the service manual the Main Relieve valve should be adjusted to increase the pressure. I found a picture showing the location of the main relief valve and tried adjusting it but there is no change. The relief valve has a cap over the adjusting screw and a locking nut. I have removed the cap, loosened the locking nut and used an Allen key to turn the adjuster in. So far I have got a total of 5 partial turns (maybe 1/8th turn each) clockwise and there has been no change. Am I doing something wrong or is the valve defective?
