Results 1 to 10 of 10
  1. #1
    New Member
    Join Date
    May 2018
    Posts
    6
    Ford 2810
    Default probelm: mower on three point hitch automatically lifts upon start up and then lowers
    Hi, I am new to this site. I have a Ford 2810 and also another tractor. The mower that I have on the back of the 2810 is automatically lifting when I start up the tractor. It stays lifted all the way for a minute or two and then it lowers itself.
    I recently put some fluid in what I think is the transmission box. Is the transmission fluid and the hydraulic fluid the same. For lack of a better explanation of my situation, I inherited the tractors and need to learn how to take care of them.
  2. #2
    Epic Contributor k0ua's Avatar
    Join Date
    Jun 2009
    Posts
    28,353
    Branson, Mo.
    Kioti DK35se Hydrostat
    Default Re: probelm: mower on three point hitch automatically lifts upon start up and then lo
    Quote Originally Posted by slicedpotatoe View Post
    Yes, the transmission fluid and hydraulic fluid are a common sump. I wonder what you put in there? Was it an approved fluid for your make and model? Was the fluid level low in the sump? I assume the 3 point lift lever was in the up position, and if so then the 3point will raise upon startup when the hydraulic pump provides fluid flow.
    If it sinks while the tractor is running you have a serious leak in the control valve or 3 point lift cylinder. The leak for either will be internal so not a leak onto the ground. If you mean it lowers itself in a minute or two after you shut off the engine, then it is still pretty serious.
    Lessons learned: Don't add fluid as a diagnostic test, Only add fluid (making sure you are adding the proper fluid) if and when the dipstick or sight glass indicates fluid needs to be added. This is done when the tractor is sitting level and all implements are in the down position.
    Lesson 2:, you likely have a problem with either the control valve or cylinder seal.
    You didn't mention drop and then an abrupt rise followed by a drop and rise again, while the tractor is running and fluid flow is being provided by the pump. Your tractor may not have position control as a feature on the 3 point. Tractordata does not say.
    TractorData.com Ford 281 tractor information
    James K0UA
    Kioti DK35se hydrostat with 2 QA buckets, 48 inch. King Kutter Rotary Cutter. 750 lbs ballast box. Loaded tires, Construction Attachments SSQA Lightweight Pallet forks. EA 50 inch single lid "wicked" Grapple. Satisfied Everlast PA160 welder owner NRA Life Member How to add a link to a post . Best way to search TBN . Igitur qui desiderat pacem praeparet bellum
  3. #3
    Elite Member CobyRupert's Avatar
    Join Date
    Oct 2012
    Posts
    3,647
    Washington County, NY
    JD 5075E
    Just a W.A.G. here, but:
    Do you have a draft control lever, and did it somehow get moved to it's most sensitive position?
    JD5075E, Frontier RC2084 Rotary Cutter, Wallenstein FX65 Skidding Winch
  4. #4
    Join Date
    Jun 2009
    Posts
    28,353
    Branson, Mo.
    Quote Originally Posted by CobyRupert View Post
    I am not sure it has Draft Coby, I am not even sure it has position control. Maybe. Some pictures would be nice.
    James K0UA
  5. #5
    New Member
    Join Date
    May 2018
    Posts
    6
    Ford 2810
    <a href="http://smg.photobucket.com/user/lundy/media/20180508_151544_zpsdtrzseai.jpg.html" target="_blank"><img src="http://img.photobucket.com/albums/v302/lundy/20180508_151544_zpsdtrzseai.jpg" border="0" alt=" photo 20180508_151544_zpsdtrzseai.jpg"/></a>
  6. #6
    New Member
    Join Date
    May 2018
    Posts
    6
    Ford 2810
  7. #7
    New Member
    Join Date
    May 2018
    Posts
    6
    Ford 2810
    It does have a Draft control. I am not sure how it works. I have pictures but am having trouble posting them. What do you all use to post pictures.
  8. #8
    New Member
    Join Date
    May 2018
    Posts
    6
    Ford 2810
    The Draft control lever is all the way down. I guess I need to move it midway. I think I have the right hydraulic oil in it. It is John Deere low viscosity hi gard transmission and hydraulic oil TY22000.
  9. #9
    New Member
    Join Date
    May 2018
    Posts
    6
    Ford 2810
    It doesn't jerk. It just slowly rises and stays up for a minute then fails. After that I go about my business and cut grass and don't notice anything.
  10. #10
    Elite Member
    Join Date
    Sep 2007
    Posts
    3,430
    Doniphan, Mo.
    Kubota L4240, B7800 & BX2660
    Is there more then one spot on the tractor that you can hook the top link, if so try the other hole.
Similar Threads
  1. 3-Point Hitch Case-IH 895 three point hitch only lifts half way
    By high road in forum Case-IH
    Last Post: 04-28-2018, 05:48 PM
  2. H Boomer 8n RPM Automatically REV's to full on cold start.
    By Kbauer in forum New Holland Owning/Operating
    Last Post: 01-03-2014, 04:41 PM
  3. 3-Point Hitch CT335 - 3-point hitch raises normally but lowers very slowly.
    By demoman357 in forum Bobcat Tractors
    Last Post: 04-05-2013, 04:11 PM
  4. 3-Point Hitch 3 point hitch lifts unevenly - TC24DA
    By flumpydog in forum New Holland Owning/Operating
    Last Post: 12-22-2008, 10:58 PM
  5. ONE of the 3 point lifts not lifting! 7500hst
    By skeptical in forum Kubota Owning/Operating
    Last Post: 03-27-2008, 04:26 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2018 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
