Results 1 to 5 of 5
  1. #1
    Bronze Member merlintractor's Avatar
    Join Date
    Feb 2009
    Posts
    85
    Colorado Front Range
    MF 1260
    Default MF loader cap plate leak
    I've sprung a leak at the joystick cap plate on my MF loader. My plan is to remove the plate, clean the surfaces and reseal with blue RTV. My question is, how much do I torque down the three retaining bolts? This my first DIY hydraulic repair...not my strong suit. Any advice appreciated.
    MF 1260, MF 1246 FEL, 48" Markham Grapple, Betst Flail Mower, Wallenstein BX42 Chipper, Rhino Rear Blade, Land Pride BB2572 Box Scraper, Ford '94 F-250HD
  2. #2
    Join Date
    Oct 2015
    Posts
    624
    Hudson Valley, NY
    MF Utility 35 Gasser
    Default Re: MF loader cap plate leak
    Quote Originally Posted by merlintractor View Post
    Post some pics, I'm not sure RTV is the way to go with this.
  3. #3
    Join Date
    Feb 2009
    Posts
    85
    MF 1260
    Quote Originally Posted by shaeff View Post
    Here you go...sorry it took so long, a little busy.
    Attached Thumbnails Attached Thumbnails MF loader cap plate leak-20180608_165838-jpg   MF loader cap plate leak-20180608_165915-jpg   MF loader cap plate leak-20180608_170015-jpg   MF loader cap plate leak-20180608_170047-jpg   MF loader cap plate leak-20180608_170104-jpg
  4. #4
    Join Date
    Jul 2009
    Posts
    1,855
    IL
    B2710
    That seal, and the orings on the spool, are low pressure seals. The high pressure seal is provided by the machined surface of the spool. So if you've got a constant source of leaking oil, it's likely the spool is scored or damaged. With the cap off you can probably figure out which spool is leaking, then you can pull that one and inspect it. It's also possible the valve body has been distorted if its mounting configuration or tightness has been changed in some way.
    Kubota B2710, John Deere X738 snowblower, Toro Zmaster ZTR, King Kutter bush hog, New Idea manure spreader, Swisher trail mower.
    Lincoln Square Wave 200, Lincoln 225 AC/DC, Harris Oxy/Ac.
  5. #5
    Join Date
    Feb 2009
    Posts
    85
    MF 1260
    Quote Originally Posted by BeezFun View Post
    Ok, thx! I'll pull the cap plate and see what I can find.
Similar Threads
  1. Oil Leak From Fill Cap?
    By ntventure in forum Parts/Repairs
    Last Post: 05-21-2016, 04:39 PM
  2. Branson 3510I fuel filler cap leak
    By DaveS2 in forum Century & Branson
    Last Post: 08-01-2012, 12:09 PM
  3. Oil & Fuel Leak in tansmission behind clutch inspection plate
    By Johnnyt321 in forum Massey Ferguson Owning/Operating
    Last Post: 02-19-2011, 04:57 AM
  4. Oil & Fuel Fuel Cap Leak Branson 4020
    By ronT in forum Century & Branson
    Last Post: 08-02-2007, 08:39 AM
  5. RTV 900 Fuel cap leak??
    By inseeme in forum ATVs & Utility Vehicles
    Last Post: 03-14-2006, 09:46 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2018 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
