Results 1 to 9 of 9
  1. #1
    Super Member /pine's Avatar
    Join Date
    Mar 2009
    Posts
    7,831
    Default 3 PH side link cylinder sources...
    Can anyone suggest online resources for wide varieties of hydraulic cylinders other than Surplus Center???
    I'm wanting a new (bare bones) cylinder that I can add custom link ends to...
    Looking for a 2.5" to 3" bore with a minimum of 4"stroke...retracted length should be 13" or less...
    Want a welded cylinder for easy fabrication...I'm afraid tie rod cylinders use cast ends...I need to be able to MIG custom pin ends to the cylinder...
    I have scoured the Surplus Center site and want to make sure there is not a better more ready applicable cylinder available...I do not want to buy "unused (old) inventory"...as it is not uncommon for rod end seals to dry out and start leaking after a very short time...
    I do not want a generic pre-fabricated side link to start with...just too much $$
    Slash Pine
    blunt and succinct yet sincere I don't suffer fools and morons...in the immortal words of Popeye..."I yam what I yam"
  2. #2
    Elite Member
    Advertiser
    MtnViewRanch's Avatar
    Join Date
    Mar 2005
    Posts
    9,476
    4000\' mountains of Southern California
    Mahindra 7520, Mahindra 3215HST, Case 580 extendahoe, Case 310 dozer, Parsons trencher, Cat D6,
    Default Re: 3 PH side link cylinder sources...
    I'm not sure you will be able to find a double acting cylinder in the size range that you need with no ends. Probably going to have to get a welded unit and cut off the ends. I recommend that you get a tube type welded unit and go from there. Maybe Bailey?
    What tractor are you building this for? Are you going to build it to get single side tilt, or to tilt in both directions equally?
    Brian
    Top and Tilt Kits by Fit Rite Hydraulics
  3. #3
    Super Member Inspector507's Avatar
    Join Date
    Mar 2002
    Posts
    5,915
    Central Ohio
    Try Hay Tools
  4. #4
    Join Date
    Mar 2009
    Posts
    7,831
    Quote Originally Posted by MtnViewRanch View Post
    B1700 (basically same as 2100, 2400)
    Yeah I don't mind cutting off whatever is on a cylinder...just have to work out the lengths...I'm replacing a leaking cylinder I made about about 8 years ago out of a surplus cylinder that I have no information on...
    Quote Originally Posted by Inspector507 View Post
    No thanks...I have a leaking top link I got from them and they want something like $5 for one thin o-ring and another $5 to mail it to me...also the dpcv messed up and started rattling...if it's hay season it would take a month to get a part...
    Slash Pine
  5. #5
    Elite Member
    Advertiser
    Join Date
    Mar 2005
    Posts
    9,476
    Quote Originally Posted by /pine View Post
    I use a 4" stroke unit and with a small modification to the lower clevis, Then you have a unit that gets you an equal amount of tilt angle to each side.
    Why would you use a 2 1/2" or 3" dia unit? 2" is more than enough for that tractor. I'm not sure that a 3" dia unit would even fit? :confused3:
    Attached Thumbnails Attached Thumbnails 3 PH side link cylinder sources...-img_2653-jpg
  6. #6
    Veteran Member TMGT's Avatar
    Join Date
    Jul 2015
    Posts
    1,017
    Stafford, VA
    B2620
    What about Purpose Built Hydraulic Cylinder Specialists - Aggressive Hydraulics ?
    I've never bought from them but look interesting, and I agree with mtnview, the side link I built for my B2620 was only a 1.5in bore with a 6in stroke (stroke was a little long buy used what I could find at the time).
    2in would be the max I would use.
  7. #7
    Join Date
    Jul 2015
    Posts
    1,017
    Stafford, VA
    B2620
    3 PH side link cylinder sources...-ncm_0824-jpgFound a picture of my tilt cylinder.
  8. #8
    Elite Member countrybumpkin's Avatar
    Join Date
    Jun 2005
    Posts
    2,569
    Southeast Missouri
    Kubota L3410; Kioti NX5510C
    Try bailey, I order stuff from them a lot.
    Shopping
    If your going to be a Bear, Be a Grizzly!
  9. #9
    Join Date
    Mar 2009
    Posts
    7,831
    Thanks for the replies and advice...not sure why I was looking for such a large bore cyl...likely because that is what I had on hand that I could make work 8 years ago when I first fabbed a tilt cyl,
    ...It was a 4" stroke and I did set it half extended when I set the length to what the solid link was...gave me plenty of tilt in both directions...
    I will expand my search now to include down to 2" bore cylinders...thanks again for the advice and the links to the sources.
    Slash Pine
Similar Threads
  1. marking hydraulic side link cylinder
    By /pine in forum Hydraulics
    Last Post: 08-12-2010, 02:18 PM
  2. Modifying a side link cylinder
    Last Post: 03-27-2010, 07:14 PM
  3. Hydraulic Side Link Cylinder Recommendation
    By Cocre in forum Hydraulics
    Last Post: 03-04-2010, 06:36 PM
  4. Side Link Cylinder Operates to Fast!!!
    By Lasgambler in forum Hydraulics
    Last Post: 11-06-2007, 06:09 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2018 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
