Results 1 to 7 of 7
  1. #1
    New Member
    Join Date
    Sep 2010
    Posts
    2
    massey ferguson
    Default John Deere 750 partially stuck valve in remote lever hydraulic assembly
    I have a John Deere 750 4x4 tractor with a factory front loader. On the remote lever hydraulic assembly for operating the front loader, the valve for curling the bucket works fine (both up and down). Moving the right lever forward and back, I can move its corresponding valve in the valve assembly full in and full out (full range). But moving the left lever forward and backward, I can move its corresponding valve full in, but only partway out, so the front loader drops down quickly but lifts slowly. I have to pull back pretty firmly on the left lever to pull the valve out far enough to get the loader to lift at a decent speed. My guess is that there is gunk stuck in the upper valveç—´ channel preventing it from moving fully out. Anyone know how I can diagnose and clear its channel?
    John Deere 750 partially stuck valve in remote lever hydraulic assembly-valve-asmbly-top-view_lores_960px-jpg
    John Deere 750 partially stuck valve in remote lever hydraulic assembly-valve-asmbly-top-view_closeup_960px-jpg
  2. #2
    Elite Member
    Join Date
    Jan 2010
    Posts
    3,893
    Northern, IL
    Branson 2400H, JD X540
    Default Re: John Deere 750 partially stuck valve in remote lever hydraulic assembly
    There should be a cover on the opposite end of that spool (behind the hose connections) carefully remove this cover to see if the centering spring assembly is still correctly assembled. Some of these have a screw that can work loose preventing full movement in one direction
  3. #3
    Join Date
    Dec 2012
    Posts
    1,763
    Williamstown Ontario Canada
    Kubota M7040 Nuffield 465
    Sure looks to me like some bolts have fallen out.
    Now the levers do not have a proper pivot to make the spools go in and out properly.
    Dave M7040
  4. #4
    Elite Member
    Join Date
    Jan 2010
    Posts
    3,893
    Northern, IL
    Good eyes Dave
    Agree it does look like the pivot bolts are missing.
    Artificial Intelligence will never overcome natural stupidity.
    Branson 2400H MMM & FEL
    JD X540
  5. #5
    Elite Member Zebrafive's Avatar
    Join Date
    Aug 2010
    Posts
    3,901
    South West MI
    John Deere 2030, John Deere 6415
    Good call DaveM7040
    Here is a drawing from JD parts catalog that might help
    Attached Thumbnails Attached Thumbnails John Deere 750 partially stuck valve in remote lever hydraulic assembly-750scvlevers-gif
    John Deere 2030 JD 245SL Loader
    John Deere 6415 mfwd JD 640SL Loader
  6. #6
    Join Date
    Aug 2010
    Posts
    3,901
    South West MI
    You could still have problems with the valve itself. Check under covers 11 & 12. NOTE there are small parts, springs, balls that could get lost!!!!
    Attached Thumbnails Attached Thumbnails John Deere 750 partially stuck valve in remote lever hydraulic assembly-750valve-gif
  7. #7
    Join Date
    Dec 2012
    Posts
    1,763
    Before diving into the valve itself, it is a rare occasion when you can make things better without special skills. Far more likely to end up with a bigger problem.
    The missing parts is your problem. Should be a cheap and easy fix even without the proper parts.
    Dave M7040
Similar Threads
  1. Adding selective control valve to John Deere 750
    By Moondoggy in forum Hydraulics
    Last Post: 08-25-2017, 05:09 PM
  2. John Deere 820 Stuck Shift lever question
    By Spartacus1 in forum Owning/Operating
    Last Post: 07-01-2013, 03:04 PM
  3. Replies: 0
    Last Post: 06-03-2013, 10:08 PM
  4. john deere 750 hydraulic pump
    By nicracing in forum Parts/Repairs
    Last Post: 07-28-2012, 07:08 AM
  5. john deere 750 hydraulic problem
    By redneck521009 in forum Hydraulics
    Last Post: 05-15-2012, 09:45 AM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2018 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
