jonsstihl
Is there such a thing as a log splitter valve that will operate like I want .
I want to be able to push down and have the cylinder extend and then when I let go of the valve I want the cylinder to retract without me pushing the valve up. and it would be nice if it could pop off hydraulically when the cylinder reaches the end of its stroke.
I am planning to build a 3pt tractor splitter because I can't find any locally that are set up the way the one I borrow is.
Is there a term for cylinders that have a mounting plate on the cylinder so that the majority of the cylinder is sitting above the mounting plate unsupported. I'm looking for a cylinder to upsize slightly from the splitter I borrow. The existing cylinder is a 4" OD I'm assuming that is a 3.5" cylinder but it may be a 3" cylinder.
I'm somewhat familiar with the terminology but I need a little help on this one to make sure I get what I want. I think I need a valve that will spring center to a work port with hydraulic pop off.
I just re-read the description after typing my question and I guess this valve will do what I want https://www.northerntool.com/shop/tools/product_472_472 So I just need help with teh terminology of the cylinder. Sorry I don<t have pictures, the splitter is not here right now which is why I am thinking of building one.
If you look at the last page of the pdf that is the style of cylinder I am looking for. The problem with that splitter is that the bottom plate is way to thick. just like the wallensteins. I want one with a bottom plate 1" inch thick so I can slide it under a round I can't lift.
