Page 1 of 4 1234 LastLast
Results 1 to 10 of 31
  1. #1
    Join Date
    Jun 2004
    Posts
    55
    Central VA
    NH TC29D
    Default Hydraulic Angle Rear Blade
    Has anyone added a cylinder to a standard rear blade (customized) so that the blade can be angled hydraulically from the tractor rear remote?
  2. #2
    Gold Member kubotabilly's Avatar
    Join Date
    Feb 2005
    Posts
    343
    Central PA
    3430 HSTC, BX 2200
    Default Re: Hydraulic Angle Rear Blade
    JD,
    I put a cylinder on my Woods RB84. When you have a cab tractor, why get out into the cold to angle that blade [img]/forums/images/graemlins/grin.gif[/img]. I will post a photo tomorrow night.
    Bill
  3. #3
    Join Date
    Dec 2004
    Posts
    212
    Central TX
    Kubota M9000HDC3, Kubota B7500
    I want to. It's on my list. Seems like it ought to be pretty simple. Seems like you would also need tilt.
    I haven't performed a search, but I bet someone has done it.
  4. #4
    Join Date
    May 2001
    Posts
    2,385
    Michigan
    New Holland TC40D Supersteer
    See the thread Land Pride Blade Customized.
  5. #5
    Join Date
    Feb 2005
    Posts
    343
    Central PA
    3430 HSTC, BX 2200
    JD,
    Here's a photo of my cylinder setup.
    Attached Images Attached Images
  6. #6
    Join Date
    Feb 2005
    Posts
    343
    Central PA
    3430 HSTC, BX 2200
    Here's one more
  7. #7
    Join Date
    Feb 2005
    Posts
    343
    Central PA
    3430 HSTC, BX 2200
    JD,
    My setup allows the blade to be angled to within about an inch of the original manual blade holes. More than enough angle. I used a 2 x 8 hydraulic cylinder. I was not concerned about reversing my blade and pushing backwards. I pull all my snow and gravel towards the tractor.
    Bill
  8. #8
    Veteran Member GuglioLS's Avatar
    Join Date
    Feb 2005
    Posts
    1,119
    Edgewood, NM USA
    Jinma 354, 1953 Ford NAA Golden Jubilee, Komatsu Bulldozer
    Great idea and nice work on the hydraulic angle adjuster thinga mabob. I think I will have to copy your work. This also makes me think about using a hydraulic motor for 360 degree rotation.
  9. #9
    Super Member
    Join Date
    Oct 2003
    Posts
    7,345
    Northeast, Ohio
    TC-40D SS New Holland
    Bill the hydraulic police are on to you now. Did I see common black pipe fittings (90 degree ells) subject to brute hydraulic force? If so a definite no-no in the hydraulic world. [img]/forums/images/graemlins/wink.gif[/img]
    Nice set up with the cylinder, gives me a few ideas myself. [img]/forums/images/graemlins/grin.gif[/img]
  10. #10
    Join Date
    Feb 2005
    Posts
    343
    Central PA
    3430 HSTC, BX 2200
    PR,
    Guilty as charged [img]/forums/images/graemlins/blush.gif[/img]. FYI, two days ago I ordered the proper fittings from the surplus center and they should be here in a few days. Please, anyone out there thinking about doing a hydraulic project, use the correct hydraulic fittings. Spraying hydraulic oil IS very dangerous. Just to give you alittle background on my cylinder, it's 12 yrs. old and has been on 3 different pieces on machinery with those same black pipe fittings. It was one of those things that I used those fittings to test the unit and never got around to replacing them with the proper fittings. Everyone who is guilty of the above, please stand up!!!!!!!!!!!!!!
    Bill
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2018 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
