Page 1 of 4 1234 LastLast
Results 1 to 10 of 38
  1. #1
    Silver Member mars1952's Avatar
    Join Date
    Jan 2007
    Posts
    238
    Western North Carolina
    1999 John Deere 4300 12/12 sync-reverse
    Default How do you make a hydraulic top link float?
    I plan on adding a Top & Tilt (with two tilt cylinders) to my JD4300. I already have the 3rd, 4th and 5th SCVs. I would like the top link to be able to float so that when I mow with the bush hog or rear finish mower they will have a greater range of motion and follow the contours of the land better. Most top link setups have a check valve to keep the top link in the set position. Is it possible to have a check valve and still have float?
    It would also like to rig the two lift cylinders so that I could operate them one at a time or in parallel. My extra SCV levers are in a neat row on the right fender so I could just work two at a time to move both lift cylinders at a time but I would like to be able to do it with one lever.
    Thanks in advance for your help,
    Marshall
    John Deere 4300, 420 loader, model 47 Backhoe and many other attachments.
    Ford F350 Super Duty 4X4 Crewcab
    Polaris Ranger XP 700
    Millermatic 251 MIG welder
    Miller Spectrum 625 Plasma cutter
    Upgrading John Deere Loader Cylinders
    John Deere 420 loader quick hitch rebuild
    Semi-Metallic Emergency Brake Pads for the Polaris Ranger
    Straightened, reinforced and added toothbar to FEL bucket
  2. #2
    Epic Contributor Bird's Avatar
    Join Date
    Mar 2000
    Posts
    40,453
    Texas
    Default Re: How do you make a hydraulic top link float?
    It seems to me that if you want a "float" option, you'd need to have a hydraulic valve with the float option; i.e., just as front end loader valves have the float position past a detent. I can't say for sure, but I don't think you can do that with the valves you have.
    In order to be able to work the two tilt cylinders both independently and together with a single lever, the only way I'd know to do that would be with a joystick arrangement.
    Bird
  3. #3
    Super Star Member
    Join Date
    Feb 2006
    Posts
    12,103
    VA
    JD2010, Kubota3450,2550, Mahindra 7520 w FEL w Skid Steer QC w/Tilt Tatch, & BH, BX1500
    I think youll have to replace one of your remote valves with one having a detented float function. Surplus center lists one - Item#9-5490. It is a Cross. Dont know if you can retain the check valve function. Mad would know, but hes gone as I just learned today. Now weve all got to come to terms with that. Maybe it has been answered previously. Did you do a search?
    larry
  4. #4
    Veteran Member jeffinsgf's Avatar
    Join Date
    Mar 2005
    Posts
    1,256
    Springfield, MO
    JD 4410
    I very likely could be wrong, but I don't think you're going to get either of those jobs done.
    You could rig a valve with a float position all right, but I don't think the response time is going to allow the amount of travel you're expecting in the time necessary for a smooth cut.
    On the tilt cylinders, I think you can work them independently or together, but not both.
    Do a search on "check chains" for rotary cutters. I think that might solve your issue easier and less expensively.
    4410 ePR, 3rd SCV, Skid Plates, TuffTop Canopy
    430 FEL, 48 BH, MX-5, Bush Hog Chipper, and more.
    455, 60" deck, MC-519, 3pt hitch
  5. #5
    Join Date
    Mar 2006
    Posts
    165
    Mendocino County, CA
    JD 3320
    Mars:
    For the top link put a T at each end of the cylinder and connect with hydraulic line and an appropriate valve. With the valve open fluid flows from one side to the other and the link will float. With the valve closed it acts as per usual.
    Steve
  6. #6
    Super Member JerryG's Avatar
    Join Date
    Apr 2000
    Posts
    7,235
    Northwest Arkansas
    MF 1440-4 PowerShuttle
    Like Jeff said, you can't do it. The valve on the tractor has to have a float and the cylinder can't have the check valve.
  7. #7
    Platinum Member bobodu's Avatar
    Join Date
    Mar 2004
    Posts
    954
    Whitley County,In.EIEIO
    Farmnought.Gravely Model L,Gravely Model LI,1941 Clinton two wheeler
    Tie it to a log.........
    Sorry...just couldn't pass that up.
    1945 Allis-Chalmers,1967 Wheelhorse.The wife has a bubble hooded Simplicity and a Dixon.
    Anything green here- has roots or gets spent!!!
  8. #8
    Platinum Member herringchoker's Avatar
    Join Date
    Oct 2004
    Posts
    744
    New Brunswick, Canada
    Kubota B7800, Case 450
    Quote Originally Posted by SFish
    Mars:
    Steve
    Steve's idea should work. The "appropriate valve" would be some sort of ON / OFF valve. When the valve is open the cylinder should float, but to extend or retract the cylinder you would have to close that valve. I suppose if you tried to operate the cylinder (either extend or retract) with that valve open, it would feebly extend due to the smaller surface area on the rod side of the piston.
    Kubota B7800, LA402 FEL, Homemade cab, 60" bushcutter, 74" rear snowblower (shrunk to 62").
    Kubota RTV500.
    Case 450 c/w 6-way dozer.
  9. #9
    Join Date
    Jan 2007
    Posts
    238
    Mars:
    Steve
    Hi Steve: Your idea is what I vaguely had in mind and you have help me visualize it.
    I made a crude drawing:
    Float circuit
    Gut wouldn't the differences in volume caused by one side having the piston displacing fluid make this not work?
    Marshall
    Attached Images Attached Images
  10. #10
    Join Date
    Jan 2007
    Posts
    238
    Quote Originally Posted by jeffinsgf
    I considered using a chain for the top link but I was worried about rear roll over. My pastures are very steep. I like the limiting effect on the mower height caused by check chains and I might make a set.
    Thanks, Marshall
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2017 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
