HOME  DISCUSSIONS  PHOTOS  REVIEWS  CLASSIFIEDS  DEALERS  STORE
Go Back   TractorByNet.com > John Deere > JD Buying/Pricing
Show Recent Threads:
24 Hours
Since My Last Visit
Reply
Thread Tools Display Modes
Old 12-31-2007, 10:17 AM   #11 (permalink)
New Member
Default Re: Tire Clearance on 2520
I am a new 2520 owner and questioned tire clearance before I bought it. Sounded like it would not be a problem running chains on r4 tires using I-Match.Well. I am disappointed,I can tell you first hand chains would not work on my 2520.I have alot of hills and the tires have worn the paint of the three point hitch arms when fully raised in just 3 hours use. And yes I have the turnbuckles adjusted tight.Chains just wouldn't work right now even with the wheels flipped.I am machining 3" spacers now that should solve my clearance problems and enable my to run chains.Plus I will get the added stability on side hills. Still, I am kinda pissed I need to do this especially when I asked the dealer about this before i bought this tractor.
Hillstone is offline   Reply With Quote
Old 12-31-2007, 10:37 AM   #12 (permalink)
newt92's Avatar
You said the wheels are switched and still rub? The valve stems are in correct?
__________________
2006 JD 2520 w/200cx loader, Harbor Freight quick hitch, homemade pallet forks, 5' KK tiller, 5' KKxb disc, 4' landpride pulverizer, 6' Karm King finish mower, Frontier RB1072 blade, homemade 5 1/2' lawn roller at 3500lbs, 2007 and 2008 Exmark 66" with 25hp Kubota deisels, 2003 JD gator TS w/power dump, 1990 Simplicity Sunstar
newt92 is offline   Reply With Quote
Old 12-31-2007, 12:41 PM   #13 (permalink)
New Member
No my wheels aren't flipped,I beleive it will only gain about 1/2 " clearance.Maybe enough to stop the tire rub now. But will not gain enough clearance for chains.
Old 12-31-2007, 01:15 PM   #14 (permalink)
newt92's Avatar
With my valve stems in I have 1 3/8" clearance at the 3pt arms. What if you remove the quick hitch through winter, might give some clearance. Just attach your blade or blower the old way. Also if you just put chains on front tires would that be enough? Just a suggestion.
__________________
Old 12-31-2007, 03:49 PM   #15 (permalink)
I appreciate the honest feedback. I wonder if there is a tire with the same diameter, but about .75/ .80 of the width that would be available as a turf tire?
The spacers that you are making- is that for the 3 point on the tractor side or wheel spacers?
thx
AKKubota is offline   Reply With Quote
Old 01-04-2008, 08:47 PM   #16 (permalink)
New Member
IllinoisWoods's Avatar
I posted a formula some time ago for calculating overrun ratio as well as the MFWD ratios (front to rear) for both the 2320 and 2520. The formula can be used to determine if a particular front/rear tire size combination is acceptable. It is best to measure actual tire size when possible vs using the size printed on the tire sidewall. Check the following link:http://www.tractorbynet.com/forums/j...ml#post1182104
IllinoisWoods is offline   Reply With Quote
Old 01-05-2008, 03:43 PM   #17 (permalink)
Illinios...thx. That answers that.
Now if Deere would make a small mod to the 2520 they could sell one more..if not..I guess I will need to go with a 2320 or a new Kubota model.
Old 02-01-2008, 06:14 PM   #18 (permalink)
Gordnova - did the chains work?
Old 02-01-2008, 07:23 PM   #19 (permalink)
ChuckinNH's Avatar
Here are a couple of 2320 pictures.... hope they help I also attached a picture of a 2008 JD 2320, and it looks like they might have changed the turf tires to taller, and a little less wide. The Deere web site doesn't confirm that yet though.
__________________
B2620,Loaded R-4's , Wallenstein BX42 chipper, Bush Hog SQ148 RC, 4' x 8' chain harrow, and more to come...
ChuckinNH is offline   Reply With Quote
Old 02-02-2008, 09:17 PM   #20 (permalink)
Gold Member
Those tires look super-skinny compared to my 2520's, wow!
__________________
JD 2520 --- FEL, I-Match, LX4 Rotary Cutter, DR Brush Chipper, Ballast Box, 71 Flex Planter!
Deadman is offline   Reply With Quote
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
About TractorByNet.com | Terms of Service | Advertise | © 2008 TractorByNet.com
