HOME  DISCUSSIONS  PHOTOS  REVIEWS  CLASSIFIEDS  DEALERS  STORE
Go Back   TractorByNet.com > John Deere > JD Buying/Pricing
Show Recent Threads:
24 Hours
Since My Last Visit
Reply
Trackback Thread Tools Search this Thread Display Modes
Old 05-14-2008, 02:52 PM   #41 (permalink)
Wombat125
Default Re: 2720 Specs
This is just a guess, but I suspect the reason for the three range preference is that the range selector gearbox is downstream of the hydrostatic motor.
I think folks are saying that in the JD high range, the diesel/hydrostatic system has to work too hard because there isn't enough gear reduction, whereas in the low range the diesel/hydrostatic can't drive the tractor fast enough because there's too much gear reduction.
Someone smarter than I needs to weigh in on this.
Wombat125 is offline   Reply With Quote
Old 05-16-2008, 01:25 PM   #42 (permalink)
croasdale
New Member
I'm no expert but maybe the HST ranges can be compared to a geared bicycle. You can put the bike in high gear and go from 0 to 30 mph but it will be quite difficult if you have to climb a hill at 5 mph in high. It's much easier to change to a lower gear. The tractor in high gear would have the same problem. Even though you have infinitely variable speeds from 0 to 14 or so mph in high range, the power required to go, say, 4 mph is greater in high range than in low range because of the different gearing.
Back to the 2720, would y'all agree it's a modernized replacement for the 955? About the same weight, power, standard MFWD, 2 range HST...
croasdale is offline   Reply With Quote
Old 05-23-2008, 11:17 AM   #43 (permalink)
jimgerken
jimgerken's Avatar
The gear choices are the same 'cause they keep re-using the SAME Kansai transaxle. I imagine it is very painful to start over designing with a new transaxle, since it is the basis of the tractor. Many new parts, very little re-use, more expensive. My 2520 has the same trans as my old 4100 had, and it appears (at first glance, from your descriptions) they re-used it again on the 2720. Now, if only it had a hi-low range shift on the go, added to the current two-speed range set, and hydro of course, you'd really have something.
jimgerken is offline   Reply With Quote
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Forum Jump
About TractorByNet.com | Terms of Service | Advertise | © 2008 TractorByNet.com
Page generated in 0.10931 seconds with 11 queries
