#1 (permalink) |
I like the forks dd, hope they work out for ya, as I am hoping the same results for the Frontier bale spear that I just got. Very nice fit and looks to be good quality. #AL1202E from JD.
I have a local farmer who will scale down his 1/2 ton bales down to 5-600lbs so I can handle them, (I'm gettin too old and lazy to buck 10 ton of small bales per yr). Now I got to thinking with this thing.===== How can I make this frame work with some sort of pallet forks? The spears are just bolted on, and the frame looks similar to the Frontier fork frame. So I am now on the hunt for forks and thinking on how to make the frame work for both. My thinking is, unbolt spears when not needed, and make some brackets to hold either the U- style forks or the round shaft style. And interchange between the 2 as my needs change. Seeing how hay stacking is only temporary, and the forks are used more often. Also would take up less space for storage and not have to buy another attatchment from Deere, (I'm stingy with my $, and justifying another attatchment to the wife is a different story), we know how that can be Does anyone have any insight or ideas that will assist me with this type of interchangeable idea? Good or bad comments are appreciated. Thanks fellas, jjmarotz Btw, if all else fails, I invite yall to a good old jousting competition, hahaha. |
#2 (permalink) |
Hello, I don't know how much help it'll be in your case, but here's a pic of a bale fork I have that also works great for moving pallets. Rather than 1 spear and two smaller stabilizers below, it's got to large spears where the pallet forks would normally go. I can't adjust them but most pallets in these areas are all the same size anyway. From a bale stacking perspective, it's really good cuz I can spear closer to the bottom of the large 7-800 lb square and stack them 3 high no problem.
__________________
2007 John Deere 2520, 200CX loader, Allied rear mount blower, 60" Buhler RFM, i-Match hitch, ballast box, 25 gal electric sprayer, 60" Buhler box blade, 60" Kodiak rotary mower, Moosehead beer holder. |
#3 (permalink) |
Update to those who need to know, the original order of the #AL1202E, came in as the #AL1301E spear.
JD has discontinued the 1202 due to multiple failures, and my local dealer did not know this, nor did I when the order was placed. JD tech delivered the spear a few days ago and I went in to pay today and found the price was up 100.00 from the original quote, now had to pay 550.00, but at least I don't have a piece of junk that will break, or harm me or the tractor. Apperantly Bueller, who makes this line of Frontier attatchments had not done sufficient R&D on this model and had numerous failures before being pulled from the line. Let's hope their forks, and other similar attatchments don't have issues either. Might be worth a call to your dealer to see what is still allowed and what has been recalled or discontinued, for everyone's sake. JJ out. |
#4 (permalink) |
Those are slick. I bought 2 bale spears - one for each tractor. I wish I didn't have to keep track of which one fit which tractor...
D.
__________________
------ Darin Divinia Red Oak, Texas Registered Texas Longhorns www.thediamonddranch.com JD 5525, JD 4720, JD 467, Polaris Ranger Crew, etc. |
#5 (permalink) |
If you have the tools, skill and steel then you can build you own. I bought my Kubota branded FEL bale speer and am very happy with it. They are a little spendy, nearly $600 with MTach brackets. I handle 700 to 800 LBS. dry hay 4x5 round bales and wrapped 4x5 haylage bales that weigh upwards of 1500LBS. No failures, no problems, less than 60 seconds to switch from bucket to speer. If there is any way you can afford an FEL speer you will not regret it.
Good Luck! Dave |
| Thread Tools | |
| Display Modes | |
| About TractorByNet.com | Terms of Service | Advertise | © 2008 TractorByNet.com |
