2320 mmm & clearance
   / 2320 mmm & clearance #1
unreconstructed
West Texas
JD 5325 JD 5203 JD 2320 LT 133
Just read the thread about clearance problems with JD belly mowers. Are there any clearance issues with a MMM on the 2320? Thanks for input--hoping to get a 2320 this year or next.
   / 2320 mmm & clearance #2
What do you mean by clearance issues?
See the thread about 5 below this one RE: Use care when buying a JD belly mower---he's talkiing about mower clearance and getting stuck in uneven terrain.
   / 2320 mmm & clearance #4
Overall, I feel the deck in it's lift height and ability to take on and off is outstanding. Also, I find the mow quality to be very good. However, I assume you are asking about the wheels/gouging into the turf? Personally, I have not experienced this, but I do run my "wheels on the four post" a bit higher than recommended, so you will get a little uneven cut if you approach a hill side ways, but I have yet to get the wheel in the correct position using this setting and it tends to line-up in the correct position before this happens. :D
   / 2320 mmm & clearance #5
No clearance issues yet with my 62D mmm. Does a nice job on my yard and I have not had the gouging problem yet either.
2011 Nissan Rogue SUV (A53424)
2011 Nissan Rogue...
2011 Ford F-350 Knapheide Service Truck (A51692)
2011 Ford F-350...
40' High Cube Multi-Door Container (A53314)
40' High Cube...
2021 Ford F-600 4x4 Service Truck (A55852)
2021 Ford F-600...
2024 JOHN DEERE 1025R LOT NUMBER 106 (A53084)
2024 JOHN DEERE...
Jack Daniels Wall Art (A55853)
Jack Daniels Wall...
